Old 08-17-2015, 03:05 PM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by JSE View Post
Getting ready to order some parts. When you guys are saying igniter/flame sensor, are you talking about the spark probe? It's basically the pilot.
It is the electronic board called UIB (universal igniter board). I got mine from this guy. Spoke to directly on phone! Helped isolate and ensure this was the issue!... R & G Electronic Home
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-18-2015, 08:31 AM   #16
JSE
2008 22' Safari
Seattle , Washington
Thanks. I have a spark probe I'm going to try this weekend and if that does not do the trick, I will call R&G and order a new igniter board. Fingers are crossed but regardless, I'm learning about the heater system.
JSE
JSE is offline   Reply With Quote
Old 08-18-2015, 09:17 AM   #17
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . as my old man frequently reminded me, do the easy stuff first, Dummy. Clean tube & replace thermocouple (cheaper than board) It's worked for me in the past., regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-18-2015, 09:50 AM   #18
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
It's not the problem most of you are chasing, but when we first got the AS, our heater would not run after initial startup. Symptoms included low water pressure and immediate shutdown in electric or gas mode. The unit had been winterized and the isolation valve was not returned to the open position at commissioning. Since the valve is hidden behind drawers, it took some investigation to find that it was still closed. Pat
Old 09-20-2015, 07:07 AM   #19
1964 28' Ambassador
Hot spring , Arkansas
I want to replace my water heater with a tankless anyone have any thoughts on that.? I have a 1964 Ambassador Land yacht and I thought that it's over 50 years old scares me.
Paulaale is offline   Reply With Quote
Old 09-20-2015, 09:11 AM   #20
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you can find one that fits the dimensions, no reason not to replace with one... especially if you can find a 'marine' version which can handle the movement you will have towing...
Channing
WBCCI# 30676
Old 09-21-2015, 08:04 AM   #21
JSE
2008 22' Safari
Update
Hey sorry for being late coming back to this thread. Just been crazy busy at work and out of town most weekends for various stuff.
Anyway, the spark probe seemed to do the job. The heater fires up and keep a flame.
One thing though. When I hit the switch to turn on the heater, the switch lights up red but then turns off. The heater is water heater is still running but the red light goes off. I could have sworn this stayed on before but now I'm second guessing myself. Does the red switch stay on after the heater fires up?
Thanks everyone for the advise and help. Nice to know there is such a great community if helpfule people here.
Old 09-21-2015, 09:05 AM   #22
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
On my 2008 Classic I get no light unless there is a failure to ignite. I flip it off/on and the heater goes through another lighting cycle.
I find my water heater flame will sometimes die out like its running out of oxygen. I've tried adjusting the air gate. Seemed to help but it still will do it. However it lights right back up.
Kelvin
Grrr...water heater won't stay lit Diesel1 LP Gas, Piping, Tanks & Regulators 10 10-26-2012 08:29 AM
new water heater won't stay lit. Aage Water Heaters, Filters & Pumps 16 12-16-2010 04:14 PM
Gas Water Heater Won't Stay Lit somefun LP Gas, Piping, Tanks & Regulators 13 11-02-2010 04:32 PM
Water heater won't stay on Catman6 Water Heaters, Filters & Pumps 12 01-08-2010 10:36 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
