Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 01-26-2008, 06:08 PM   #1
Airstream25
Airstream25's Avatar
Profile:  1995 25' Excella
Albuquerque , New Mexico
Images: 21
Water heater wont stay lit at high altitude
I searched the forums and did not find info on this problem.
1995 Excella propane water heater works OK at home elevation of 5,000' but will not stay lit when boondocking at 10,000' elevation. The boondocking was in July so the air temperature was moderate.
The electronic ignition lights OK and the heater burns with a normal roar for a minute or two then the roar gradually diminishes and it shuts off. Same thing happens when switching the water heater off and back on again.
I did have water in the hot water tank and I did have propane. The stove always worked OK.
When I return to the home 5,000' elevation, the hot water heater works OK again.
Airstream25
KE5CKG on 2 meters
Four Corners Airstream Unit
AIR #10274 WBCCI # 2154
Airstream25 is offline   Reply With Quote
Old 01-26-2008, 06:31 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The operation as you describe, is common to low LPG pressure.
Check the LPG pressure and let us know what it is. Please check the pressure when a heavy load is placed on the regulator.
The normal LPG pressure is set to 11-13 inches of water column pressure.
When operating at high altitudes the pressure should be set to the high side, namely the 13 inches, and it can stay that way.
You might also check the air adjustment on the burner.
Electronic ignition furnaces will also behave at high altitudes as you have described.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 01-26-2008, 06:43 PM   #3
Airstream25
Images: 21
Ok Andy, I will check the pressures tomorrow. Thanks.
Jerry
Airstream25
KE5CKG on 2 meters
Water Heater will not stay lit Beginner Water Heaters, Filters & Pumps 8 04-01-2008 01:08 PM
Pilot light won't stay lit abridges01 Refrigerators 5 09-24-2006 11:01 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Pilot Light won't stay lit Mike Callaha Water Heaters, Filters & Pumps 15 03-26-2005 12:56 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
