Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-07-2018, 06:32 PM   #1
sherrylynne's Avatar
2007 23' International CCD
vero beach , Florida
Water heater won't stay lit
Gas heater... turn the switch on, starts for 2seconds, turns itself off, will do this three times, then stops.
Any ideas? Thank you in advance.
sherrylynne is offline   Reply With Quote
Old 02-07-2018, 07:04 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
If you leave the outer door open that covers the water heater, will it stay lite?
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 02-07-2018, 07:21 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Year make model?
Newer Airstream with std Atwood heater?
The red light only comes on for a few seconds when it lights.... if it STAYS ON, you are out of propane. I know that seems counter-intuitive but that is the way it works.
Old 02-07-2018, 07:24 PM   #4
1986 31' Sovereign
Miami , Florida
There is a little rod-like thermocouple that is in the flame path on mine. It tells the control board that the gas lit and is burning. If it fails or becomes dislodged, the board will think the gas never lit and will shut down and try again. After three tries, you are "locked out" until power is cycled.
You might check to see if it is in the flame and is still connected...
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 02-08-2018, 11:54 AM   #5
2001 30' Classic S/O
Leander , Texas
Try opening both tanks, turn the valve to both,and ignite the stove for a minute. When our fridge won't run on gas, this works. After it ignites, I move the valve to one tank and close the other.
Stale propane?
John
TexAirS is offline   Reply With Quote
Old 02-08-2018, 11:57 AM   #6
Thank you for suggestion... just tried it. Did not work... but thank you.
Old 02-08-2018, 11:59 AM   #7
2018 22' Sport
North Lauderdale , Florida
On 2018 22FB Sport. The light only stays on for a second or 2 the turns off. This is normal. If light were to stay on, it’s not heating.
Lag323 is offline   Reply With Quote
Old 02-08-2018, 12:01 PM   #8
Yes... Atwood heater... propane.. Airstream is 2007 International 23'. I am looking inside of the water heater area right now. I can see it is above my intelligence level. But with suggestions from here, one of my sons may be able to make the repairs.
Thank so much for your reply!
Old 02-08-2018, 12:03 PM   #9
Thank you. It works the same way on my 2007. We have not had a problem before. Thanks for your reply.
Old 02-08-2018, 12:05 PM   #10
Oh, I am pretty sure there is propane because the stove has propane, and I see the flame in the heater as it tries to stay on. Thanks for the info!
Old 02-08-2018, 12:08 PM   #11
I see the rod- thing... and I will show this post to my son when he gets back to the campsite. Thanks for the help.
Old 02-08-2018, 12:14 PM   #12
Thank you , John. I see there is flame for a few seconds each time the electronic ignition fires. And luckily we have "fresh " propane because we lived in the Airstream in our driveway after Hurricane Irma. We filled both tanks after the storm. I did have the refrigerator fail whilst on gas... took it to the dealer... he told me to go back out to the trailer and do exactly what you described. It worked! There was air in the line, and turning the burners on got rid of the air and the refrigerator started working again. Great advice!
Old 02-08-2018, 04:27 PM   #13
Update-- we have hot water! When my son got back to the campsite, I showed him this post. He pulled out the rod thing and cleaned part of it and reinstalled... apparently being young and invincible, there was propane still in the area... lost a little bit of arm hair.... but, we have hot water! Thank you everyone for your advice and help! You're the best!
Old 02-08-2018, 04:34 PM   #14
1966 26' Overlander
Gridley , California
I had the same problem. Talked to a repair man at an RV center. His answer was to use compressed air and blow out the dirt, lint, spiders, and what ever else had made a home around the area inside the panel from the outside of the trailer. Be sure to use goggles and a dust mask to protect your face. When I did this, it worked fine - fired right up and kept working.
Good Luck!!
Iron Doc is offline   Reply With Quote
Old 02-08-2018, 06:45 PM   #15
Good Luck!!
Thank you! We will take care of that when we get back home to the compressor!
Old 02-09-2018, 09:20 AM   #16
CruizinDux's Avatar
Washington , Missouri
Semi annually I put a half of a lg dog flea collar in the refer & wh exterior openings to help keep the spiders away from the burn tube.
CruizinDux is offline   Reply With Quote
Old 02-09-2018, 04:26 PM   #17
2005 28' Classic
Sacramento , California
Water Heater Fix
I had the same problem. After cleaning it still did not light. I had to replace the ignition sense probe. it cost about $25
glhorner is offline   Reply With Quote
Old 02-09-2018, 05:29 PM   #18
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
A leaf blower works pretty good also.
Alan
Old 02-10-2018, 07:58 PM   #19
2015 25' FB Flying Cloud
Grapevine , Texas
Same problem
Water heater only lights when access door is open.
Seems not enough air moving to enable auto lighting.
Cured by slightly bending the bottom hinge side of the door OUT to increase ventilation. Not noticeable. Fixed the ignition problem and heater fires up every time.
tommyglen is offline   Reply With Quote
Old 02-11-2018, 08:40 AM   #20
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I have exactly the same problem. I thought it might be related to the elevations we camp at in Colorado (8,000+ feet). Might have to try a little door bending myself.
DaveP
2023 Ram 3500 4x4
Water heater won't stay lit in damp weather wheelygoode General Motorhome Topics 12 01-31-2016 05:47 AM
Grrr...water heater won't stay lit Diesel1 LP Gas, Piping, Tanks & Regulators 10 10-26-2012 08:29 AM
new water heater won't stay lit. Aage Water Heaters, Filters & Pumps 16 12-16-2010 04:14 PM
Gas Water Heater Won't Stay Lit somefun LP Gas, Piping, Tanks & Regulators 13 11-02-2010 04:32 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
