Old 09-15-2005, 08:30 PM   #1
John Greenlee's Avatar
Bowie , Texas
Water heater won't heat
Hello all,
I just got home today with my second Airstream. A 1966 Overlander. Beautiful trailer.
My challenge.... I can light the pilot o.k. on the water heater. However, it does not kick on to produce any hot water. In other words, the main burner never lights. Wassupwidat? The pilot just goes on and on....
Can it be a thermo couple or is the control unit necessarily bad?
JMG
John Greenlee is offline   Reply With Quote
Old 09-15-2005, 08:34 PM   #2
StingrayL82's Avatar
San Angelo , Texas
Images: 37
I would check for any obstructions in there first. From what I hear, muddaubers and those little propane inhaling spiders love it in there.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-16-2005, 12:29 PM   #3
John, this was discussed about 18 months ago at this thread:
http://www.airforums.com/forum...20&highlight=%
I hope it contains a few pointers for you.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-16-2005, 08:05 PM   #4
Bowie , Texas
This doesn't seem to be exactly my problem. My pilot burns and burns hands off, but the main burner never kicks on. I wonder if a thermocouple affects this?
JMG
Old 09-16-2005, 08:35 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
JMG
Sounds more like a thermostat. You may also have a restriction in the gas line, although I would think that would cause the thing to go out after the main burner tried to light, and starved the pilot for fuel.
Have you tried moving the thermostat setting around at all? Maybe set it higher than you would want, then throttling back when the burner lights off?
Old 09-17-2005, 11:05 AM   #6
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
Even with a new one
Hi there,
I've replaced my water heater system this summer by a new ATWOOD thermostat, pilot, burner... excep the tank.
The pilot was OK like yours and the thermostat began to produce fire to heat water and suddently stop each time after a few seconds.
ATWOOD says it was a bad model and the default was the couple inside the thermostat and they send me another one;
I suppose if this kind of part, even if it 's a new one can be wrong, the genuine one in your 66 Overlander is out with the time.
Change only, like me, all these parts and keep your genuine tank.
Bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 09-17-2005, 04:28 PM   #7
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
John, it may very well be a total obstruction of the burner tube. Those spiders are pretty pesky. I've got two trailers and had small spiderwebs in each of the burners so far this year. Both of them were small partial obstructions, just enough for the flame to be yellow and sooty.
At last years' Midwest Rally, the water heater wouldn't light on a brand new 19' Bambi. The pilot was fine, but no burner. I pulled the burner off and found a spider web totally obstructing the tube. Cleaned out the web, and it was good as new. I'd recommend you check your burner first. If you find a web in it, a bottle brush or a straw, or even a flexible stick will work.
DO NOT run anything hard through the brass orifice. If you think it needs to be cleaned, use nothing harder than a piece of fishing line. If you do, you'll be buying a new orifice real soon.
The thermocouple only affects the pilot light. Of course, the burner won't light either if the thermocouple is cold. If you have a pilot that stays on, your thermocouple is fine.
Roger
Old 09-22-2005, 07:05 PM   #8
Bowie , Texas
Well, I replaced the thermocouple and checked the burner tube. It is not obstructed. (the orifice is pretty small isn't it?) I am thinking the control unit is bad. Is there a replacement available? Mine has the original Honeywell unit from 1966. I researched using a household propane control unit, but decided it will not work -- at least because of the odd size left hand threaded outlet for the burner.
Are there new control units available?
JMG
Old 09-28-2005, 06:14 PM   #9
1969 31' Sovereign
Elizabeth , Colorado
Make sure you have make, model #for water heater.I got parts for my 69 Atwood from www.marksrv.com. Watch for yellow highlight about parts. I just bought hte complete burner unit which includes the pilot light, thermocouple and burner tube.
Hopefully you can find the parts you need.
stagecoachbill is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
