Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-02-2002, 09:30 PM   #1
airstreamcaravel
airstreamcaravel's Avatar
Profile:
Unhappy Water Heater Woes
After several years of working flawlessly, My original Bowen
water heater has began a new trick. The pilot light seems to work fine. BUT when I turn up the temp dial, I get a large flame shooting out at me and it starts the air adjustment venturi a blazing!! The only way to control this is to shut down the temp.
For years it would simply shoot a nice jet deep into the heater
and worked just fine. On and off as needed to mantain the temp.
I suspect that the main burner has become rusted to the point
that the flame would rather head south toward the air adjustment window insted of north into the tank.
Any suggestion beyond the obvious of "take it to a qualified tech"
and bring wads of cash?
Thanks in advance!
67 airstreamcaravel
airstreamcaravel is offline   Reply With Quote
Old 08-03-2002, 10:07 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Wash the burner tube out with water. Sounds almost like you have some spider webs in that tube.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 08-03-2002, 10:28 AM   #3
airstreamcaravel
Profile:
Woes
Andy,
I will dismantle, inspect, attempt to repair, replace, test, and report back faithfully.
67 Caravel
Old 09-07-2005, 09:18 PM   #4
halobender
halobender's Avatar
Profile:  2005 25' International CCD
Portland , Oregon
Images: 24
Deterring Spiders
What are some easy, safe ways to deter spiders from nesting in the hot water heater? Additional screening? Mothballs? I'm in my trailer full-time so the spider-attracting propane is running daily. I just had my 10 month old heater repaired after a web caused a back-flame which melted the t-set diode and another wire.
Thank you. Jill
halobender is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Water System Woes swebster Mechanics Corner - Engines, Transmission & More... 5 08-02-2003 08:21 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
