Old 02-23-2018, 01:05 PM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Conroe , Texas
water heater - with both propane & electric options
We have a 2015 27FB FC that has both propane & electric operations. We always have both turned on & have never had any problems until yesterday. The propane wouldn’t stay lit. But after reading on this forum- I switched to the other propane tank + lit the stove burner for a while & this must have relieved some air out of the line & went back to working ok. My question is why didn’t the electric thru shore power heat the water even if the propane wasn’t working?
Glenn
PSU1981 is offline   Reply With Quote
Old 02-23-2018, 01:48 PM   #2
2007 22' International CCD
A few possibilities to check:
Does the water heater have an electrical heat element? Some do not.
Assuming the water heater has a 110 volt heating element:
1) Does the heater have power both 12 volt and 119 volt?
Is the plug/wire connected
Is the circuit breaker on?
Trailer power set to "use"?
Water Heater 12 fuse good?
Sometimes the water heater is on a GFI circuit. Reset the GFI?
2) Has the heater ever been turned on with the tank empty? This can burn out the electrical heating element rather quickly...and lead to this symptom.
3) Sometimes a bad relay on the water heater control board for the 110 volt element has happened. Bit more difficult to check out.
4) Sometimes a fusible link (emergency shut-off device) can go bad and needs to be replaced.
If you have the skills, and a multimeter, these are fairly easy to troubleshoot.
If Not, ANY RV tech that knows how to service the water heater should be able to fix it. Does NOT have to be an Airstream dealer...
Is there flash heater that both propane and electric? RocketCramer Water Heaters, Filters & Pumps 14 12-11-2014 03:55 PM
Electric heater? Propane furnace? Or both? handrew Winter Living 10 11-22-2014 08:29 PM
Help newbie - hot water stopped working...tried both electric and LP Arnoldjeff Water Heaters, Filters & Pumps 4 09-06-2014 04:56 PM
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Both Furnace and Water heater won't ignite? sound-silver Electrical - Systems, Generators, Batteries & Solar 19 11-17-2009 07:30 AM
