water heater wiring
I bought an atwood 10 gal. electronic ignition water heater to replace the original. The original had a 3 wire black harness with a plug connected to the front of the heater, The rear access for the thermostat has been altered, two wires connected there. My problem is that the new heater has three wires, one is for low voltage..blue, the others I guess a re for 12 v.. says battery and ground. What is the black wire assembly on the old one, where does it feed from, looks like an extension cord, but cant find the source., unless it ties in to the univolt or in that area. It does not have power to it, dont know why. Please help and tell me how and what to connect the new wires from the heater to ?? what. There is an inside switch with the new one, I am thinking put voltage to the new switch.. but what is considered low voltage for the blue wire? confused and no hot water.
