Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-23-2006, 10:19 AM   #1
terratravelr's Avatar
Profile:  1974 27' Overlander
Merryman Station , California
water heater - vrooooom- then fizzle
one more question (for now!) - my hot water heater lights with no problemo. Takes off like a 747 jet but barely gets off the runway before something clicks, and fizzles. What the...... ????
merci beaucoup
(I honestly perused other posts first !!!)
terratravelr is offline   Reply With Quote
Old 11-23-2006, 10:30 AM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
Are you sure you have water in the water heater tank? Maybe it is bypassed.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-23-2006, 11:20 AM   #3
I believe there's water in the tank, when I open the outside overflow valve water comes out. also, the owner's manual says that if I turn on the hot water side of a faucet and water comes out, then I have water in the tank.
Old 11-23-2006, 07:38 PM   #4
Profile:  1977 24' Argosy 24
Moundsville , West Virginia
Try cleaning pilot if that doesn;t work change thermocople.
Donald 43 is offline   Reply With Quote
Old 11-24-2006, 06:48 PM   #5
steelbird312's Avatar
Profile:  1989 29' Excella
1956 22' Safari
Crossville , Tennessee
Images: 11
good connections
The very first thing I would do would be:
insure the thermocouple is in the flame
insure the pressure is set right for the gas
take every connection for the thermocouple, clean it very well, reattach it.
Now try it.
If that didn't fix it, most likely the thermocouple is bad. You can buy from an RV supplier, or buy from an appliance dealer. That one will probably take some engineering to make it work.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 02-03-2007, 12:20 PM   #6
Loren's Avatar
Profile:
Actually, that's not always true. You can get water from a faucet without having water in your water heater.
If your water heater has a bypass system you can set the valves so that water will bypass the water heater and flow directly to the fixtures without actually passing through the water heater. (Hence the name "bypass".)
Ensure that your bypass valves are set to the normal - non bypass- mode. This will cause water to fill your water heater before being directed to the fixtures.
If you don't know which valve is which (there should be three valves in the bypass system), follow these steps:
  1. Ensure that all the valves at the water heater bypass system are closed. This is usually true when the valve handle is perpendicular to the pipe. It is also usually true that you turn the valve clockwise to get to this position.
  2. Ensure that all fixtures are off, both hot and cold.
  3. Turn on the water pump and allow pressure to build up until the pump shuts off.
  4. At the water heater, open one valve. Listen to the water pump. If it runs for a long time (1-3 minutes) before shutting off, then you have just opened the valve IN to the water heater. Label this valve. You are filling the water heater with water.
  5. If the pump either doesn't run or runs only for a brief time (10-60 seconds), open the hot side of any fixture. If the pump starts and continues to run, and water flows from the fixture, you have just opened the BYPASS valve. Label this valve.
  6. If the pump remains off after you have opened the hot water side of a fixture, you have just opened the valve OUT from the water heater. Label this valve.
  7. Close the valve you just opened.
  8. Continue with each valve until they are all identified.
  9. Note, that once you open the IN valve, the water heater will have water in it so the pump will not run for 1-3 minutes anymore. The water heater will not be full, however, because the air has had no place to go. The air won't leave the water heater until the OUT valve and a hot water fixture are both open at the same time.
This does get complicated, but if you understand the system's operation you can work through the valves. Remember, you only have to do this once.
To set your water heater up for normal operation, close the BYPASS valve and open both the IN and the OUT valves. Open the hot water side of a fixture and allow the air to escape to fill the water heater. After water flows from the fixture, the water heater is full. Close the fixture and start the water heater.
If you have started the water heater with no water in it, it is probably damaged. The extent of that damage and its repair is another issue.
You said that you got water from the outside overflow valve. I assume that you mean the T&P safety valve that is spring-loaded closed and has a lever on the top to allow you to open it. If you did get water through this valve, your water heater has water in it.
Good luck. I hope nothing is burned out.
Loren
1997 - 34' Classic Limited Front Kitchen.
2008 Dodge 2500 diesel with Equal-i-zer hitch.
Loren is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 10:13 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
