Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-05-2006, 05:53 PM   #1
charlie g
Profile:  1991 29' Excella
fort worth , Texas
Water Heater Troubleshooting
I have a gas water heater. When I turn it on, switch in bathroom, it stays on for about 2 -3 min and shuts off. Any suggestions as to what I can check?
charlie g
charlie g is offline   Reply With Quote
Old 11-05-2006, 06:04 PM   #2
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Check out the search feature on the forums. Many ideas here.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 11-05-2006, 06:55 PM   #3
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Charlie,
What brand is it.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 11-05-2006, 08:49 PM   #4
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
Charlie, since you are a new poster, I wonder what it is that comes on and then goes off. Of you are saying you can hear it come on for a ful 2-3 minutes, then I would say you probably need a thermister. It also could be that the flu or chimney is stopped up; the gas has incorrect pressure; the gas bottle is empty, etc.
If, however, you are speaking of the red light on the switch, the red light indicates either a failed condition, or the process of attempting to light electrically. When the light goes off, it is lit.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 11-06-2006, 08:20 AM   #5
charlie g
fort worth , Texas
I belive it is a Atwood Heater. I do hear it light and the red light goes off. After about 2 - 3 min it goes off and the red light comes on.
Old 11-06-2006, 06:15 PM   #6
steelbird312
Griffin , Georgia
Images: 11
Charlie, Make SURE, POSITIVE SURE, that you do not have a bypass valve open, thereby causing the hot water to remain in the tank. It works like this. When winterizing, the bypass valve is opened, which keeps any water from going into or out of the hot water heater. Then, when you try to turn it on, it runs just a short time, bringing the temp up in the tank, and then shuts down, yet you get cold water from the hot tap. I have seen this more than once.
I spoke of a thermister last post, however, I really meant your thermocouple. Now,the tip of it is located in the flame, and it tells your gas valve to stay open as there is a flame, and it is safe to stay open. When they go bad, it will not allow the gas flow to continue, and it shuts down. Now, they are fairly expensive (for what they are) if you buy them from an RV supplier. They can be purchased at Home Depot, or other like store, althhough the bracket may be somwhat different, if you are handy, can be made to work for about half the price.
That may not be the problem, however, as I mentioned earlier. It is what I would chase first.
steelbird312
1989 29' Excella
Old 11-06-2006, 07:04 PM   #7
George Jr.
Profile:
I have had the same problem for about two years on my 88 which stays stationary at TCPC Airstream park.
Gentleman told me to run hair dryer on unit for short period, especially heating tube, works every time.
BTW, problem is intermident depending on temp and humidity????????
George Jr.
George Jr. is offline   Reply With Quote
Old 11-07-2006, 07:16 AM   #8
steelbird312
Griffin , Georgia
Images: 11
George Jr.
I am at TCPC right now, having my RV port built- come by and say hello if you are here now.
Next, it sounds as if you have a ground that is intermittent, especially since it works if heated (expansion) and weather has an effect.
That is another thing that Charlie might check as well as you. Take the screw out that holds the thermocouple, clean both mounting surfaces., and reinstall the screw. Then, make sure the end of the bulb is in the flame.
steelbird312
1989 29' Excella
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Water problems Dbraw Fresh Water Systems 13 06-28-2007 05:55 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 03:29 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 10:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 11:13 AM
