Old 08-06-2004, 07:36 AM   #1
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Water Heater Trouble
I have an Atwood Elec/Gas unit that is less than two mounths old. I came home to find the Ingniter light on and the water cold. I found that the propane bottle was empty. I switched to the full bottle, but the heater will not light.
Any ideas were to start diagnostic?
Don
Gunnyusmc is offline   Reply With Quote
Old 08-06-2004, 07:58 AM   #2
InspectorDread's Avatar
1987 34' Excella
Mobile , Alabama
Don
You probably have air in the gas line. Loosen the gas line connection to your water heater and let it bleed out until you smell the propane. Retighten the connection and hit the igniter. This happened to me the last time my bottle ran out.
InspectorDread is offline   Reply With Quote
Old 08-06-2004, 08:22 AM   #3
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Thanks, I will give it a try.
Don
Old 08-06-2004, 08:49 AM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
There is a safe way to do this. The above statement will work, but once you have flared the copper and seated it to the brass loosening and re-tighing it is not good for the seal. Stuff can get in and cause a leak
If the heater is a pilot light model use a butane igniter and do the normal pilot light functions, BUT keep the pilot light knob on for 30 seconds, ans keep the igniter lit for 45 seconds. Turn the knob over to on, with the igniter lit. This will open the main valve and the main burner and pilot will light.
If it is a DSI model you will need to do 4-6 restarts.
In either case be sure you have gas to the cook top first.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-08-2004, 05:08 PM   #5
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Thanks Guys!
I got it up and running. It must have been air in the line.
Don
Old 08-08-2004, 05:39 PM   #6
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Gunny - Where are you?
Hello,
Where are you located? Are you living in your AS? I am full timing here at Camp Lejeune since being recalled in Jan 03. What do you have for a trailer? I just bought a 1965 Caravel that I have at the base hobby shop working on the tongue hitch.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water Heater By-Pass? TroutStream Water Heaters, Filters & Pumps 4 09-01-2004 07:15 PM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
