Old 06-04-2004, 12:18 PM   #1
zduke4x's Avatar
Water heater, toilet problems on a MH
Been gone awhile, so it is good to be back, even with problems.
1. After a heavy rainstorm my water heater started and continues to blow the 20 amp fuse that powers the control panel. Assume it is the auto pilot but how to fix?
2. I have a Galaxy/Starlite thetford valve type commode made of plastic that is progessively leaking clean water thru the valves that you flush it with. I can reach, barely, back there and a daily change of a old towel is stemming the flow but need to know if those valves can be fixed or is it time for a new sitter.
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 06-04-2004, 12:33 PM   #2
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I can't address your water heater problem, but I replaced a similar commode in my '85 motorhome. I bought a new one, then took the old one out to install the new one. It looked like the old one was probably repairable; I suspected that the old plastic hoses were just old, stiff and brittle and didn't seal well on the valve body any longer. Either way you'll have to pull the old commode up, but I wouldn't buy a new one 'til you get the old one off and assess what's actually going on with it. If it's a cracked valve body, it's probably time to replace the unit.
Remember that there are two nuts holding it down; the front one is pretty easy to get to. The back one has to be accessed through a port in the commode body that has a little cover that you pry out. You'll have to unscrew that one by feel as you won't be able to watch what you're doing.
Bear in mind that the new toilets DON'T have the same footprint nor do they have the same bolt pattern position as the old one, although the black seat can still be used if you turn it 30 degrees or so. I ended up re-engineering the entire platform that the commode sat on in the 325 as it was too short for the new commode base, and had a heat duct running under it. It was NOT a good time, but it worked out and really looked nice when I finished it.
Check out this thread for more info:
Thetford commode thread
Roger
Old 06-07-2004, 03:20 PM   #3
zduke4x's Avatar
commode
thanks Roger,
Found the back bolt, now to find the time....jem
The Silver Buffalo
WBCCI # 14067
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
