Old 01-29-2014, 12:50 PM   #1
1972 21' Globetrotter
Wylie , Texas
Water heater tank hole repair at fitting: weld?
I have a small hole about the size and shape of a BB just inside of the threads at the cold water intake. I took it to a welder whose charge would be $35 to fix. Due to the in accessibility directly, he would cut a flap behind the fitting to allow access to repair the hole from the inside of the tank. He would then fold back the flap and weld it secure.
It all seems reasonable to me. I am not sure about the age of the heater, but it is an Atwood G6-A7 according to its spec sheet tapes by the control panel. Interestingly, it still has a price tag for $294.67. I include this to help date it. It does have a tremendous build-up of scale (white powder) that keeps flaking out of it.
My feeling is that it might have been a slight pinhole that became a good place to eat away the metal. I searched with the term 'weld' and found an older thread by stickbug about a failed attempted weld along the halfway seam with jb weld. But that got me thinking about making a plug with some metal epoxy weld to repair this. Any thoughts? Plug? Weld? Scrap?
If the picture attaches you can barely see the whole above and to the left of the behind a blob of weld that looks like a face profile.
rippie is offline   Reply With Quote
Old 01-29-2014, 01:06 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
It's not original to the trailer. You can buy them for less than that today if you shop around, although you might want to upgrade to an electronic ignition unit or one with an electric element as well as a gas burner.
Since a new drop-in replacement is available at reasonable cost, I would suggest you scrap what you have now.
Old 01-29-2014, 01:30 PM   #3
Ottawa , ON
I agree with Jammer: this is a device that has potential to make a huge mess in your trailer if it lets go, and what the corrosion that caused the hole, and the corrosion that is building up inside is telling you that it has reached the end of the string, no matter how old it is.
Treat yourself to a new one, and go with the electric start at the least.
Old 01-29-2014, 01:31 PM   #4
Kevin245's Avatar
Ditto on scrapping the WH. This is a pressure vessel that is made of aluminum and of unknown age. Safety and reliability makes the cost of the replacement WH an easy choice in my book.
Kevin
Eleanor Roosevelt
Old 01-29-2014, 01:55 PM   #5
1977 Argosy 24
Milltown , Wisconsin
I agree with all the above, scrap it. Get one with electronic ignition. It makes it so easy to turn it on and off. I turn ours off at night so I don't have to listen to it run as it's right under our bed. Still have hot water in the morning when I turn it back on. All from inside and no going out in the rain to light it.
ventport is offline   Reply With Quote
Old 01-29-2014, 04:02 PM   #6
1998 30' Excella 1000
Livingston , Texas
I'm in the camp with those recommending replacement. However, I will say that I had a 5 year old Atwood that developed a pin-hole leak at the weld to the tank for that female thread fitting. Looked like a defective/incomplete weld during manufacture. Rest of the tank was sound. I repaired it 3 years ago with JB Weld. I've used it full-time since then. No leaks (I did place a Watchdog Water Alarm in the compartment to help keep an eye on it). Your repair sounds riskier. If you have the money, I would replace it. If not....
Siegmann is offline   Reply With Quote
Freezing Damage, Water Heater? resedaheat Water Heaters, Filters & Pumps 14 02-22-2014 04:56 AM
Water heater battery drain Bohemian Batteries, Univolts, Converters & Inverters 5 10-27-2011 12:22 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
How often to turn on water heater? DJW Water Heaters, Filters & Pumps 19 03-15-2011 11:56 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
