Water Heater T&P 99 Bambi Leaking, need advice
The water heater Temp. and Pressure safety valve in my 99 Bambi has started to leak. I read in the plumbing forum that the water heater T&P may be replaced with a replacement T & P from a local plumbing supplier or a home improvement supplier.
Has anyone replaced one recently in a model similar to my 99 Bambi? Results? I think the 99 Bambi has a standard 6 gallon water heater installed.
I also read in the plumbing forum to remove the T&P and use a calcuim remover to renovate. I am reluctant to do this since I do not want to risk having the current valve stick and cause a serious problem.
Thanks for your reply.
Jim Brown
