Old 02-26-2014, 05:43 PM   #1
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Exclamation Water heater shut off valve...where is it?
OK...our water heater was leaking...the floor was wet behind the pump and the tank...so we ordered a new unit which will be delivered tomorrow.
At the moment, we are in Galveston.
About 5 minutes ago Gail said there was no pressure at the sink.
I went to the bathroom at the back and the carpet was soaked.
I ran outside and water was gushing out from under the heater area...so I immediately shut off the gas to the heater and the city water supply to the entire unit.
My immediate question is....where do I shut off the supply to the water heater tank and still provide water to the kitchen and commode?
Unfortunately, the 1980 Airstream Service Manual is not specific.
Right behind the tank is a tan valve...does this shut off the supply? or is it a valve in the external rear compartment?
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 02-26-2014, 05:57 PM   #2
JFScheck's Avatar
Rockville , Maryland
Images: 33
You are looking for a divert valve, looks like lower right inline grey....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-26-2014, 06:06 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you have a water heater bypass, engage that. Usually this closes off the cold water input to the tank, the hot water exit from the tank, and opens up a bypass pipe that moves the water from cold directly into the hot water side. If you normally winterize your trailer, it means closing two valves and opening a third.
Doing this will isolate the hot water tank but will keep water flowing through both the cold and hot water outlets (although hot water outlet will discharge cold water).
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-26-2014, 06:29 PM   #4
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Many thanks for the prompt responses.
1. I don't know that I HAVE a divert valve. Could it be the valve in the picture that I attached?
I have never found the need to 'winterize' as we are near Houston and Ole81 spends the non-traveling time in our hangar.
There are two similar valves in the rear exterior compartment.
Am attaching the plumbing diagram in the shop manual....
Thanks again...
ID:	206481   Click image for larger version
31' 1981 Excella II
or
Old 02-26-2014, 07:16 PM   #5
jcanavera's Avatar
Fenton , Missouri
Images: 143
I looked at your first picture and typically if you follow the pipes going into and out of the water heater you should run into a valve. The cold water pipe usually enters the tank low and the hot exits towards the top. Shutoffs may be present on each pipe as you move away from the tank or worse case at least on the cold pipe. If there is bypass piping, that valve is further away from the tank tied to a pice of pipe that connects the cold and hot water lines together. That pipe is "upstream" from the hot and cold water shutoff valves. Typically it is in the closed position when the input and output valves from the hot water tank are open. When you winterize you close the cold water inlet and and hot water output valves and open the bypass.
Is that plumbing diagram labeled? I see numbers and letters that should correspond to a description.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-26-2014, 07:27 PM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
While I know this isn't your trailer, here is a picture of water lines and a bypass from another Airstream. You will see the 2 valves on the right. One cuts off the water going into the hot water tank, the other shuts off the output from the tank. The single valve on the left is the bypass and typically is in the open position when the other 2 valves are closed. Hope this logically explains it better.
Jack
Name:	heater bypass.jpg
Jack Canavera
STL Mo.
AIR #56
Old 02-26-2014, 07:37 PM   #7
ole81's Avatar
1981 31' Excella II
Richmond , Texas
1980 water distribution system 31' rear bath
The shop manual is for 1980 water distribution system 31' rear bath is in our manual with is for the 1980....but has a blue label on for the 1981 Supplement...which I do not find....so I assume the '80 and '81 are virtually the same.
31' 1981 Excella II
or
Old 02-26-2014, 08:17 PM   #8
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Or just turn the water pump off, get some water containers and semi Dry camp and relax a while. There'll be valves to isolate the water heater, they always seem to be very hard to see, small and hidden behind another pipe. Need at least two, one for water going into the water heater on the cold side, one for water going into or out of the water heater on the hot side.
Perhaps the leaking water heater is the safety release valve needing reset.
That schematic you show doesn't show valves at your water heater. The valves you show in post #4 are probably dump valves at the rear of the trailer, I suspect those are kept shut until you want to drain all the lines, there may be short pipes beyond those sticking down toward the ground.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 02-26-2014, 08:20 PM   #9
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Water tank shut off valve....
I appreciate all the input.
\Unfortunately, virtually all manuals are written by the engineers who develop the system, and are never reviewed by new users.
The page with the diagram lists 2 Stop Valves, 1 Check valve, and 1 Relief Valve....but NO description of where to find them or what the function is.
Here is a full pic of the compartment with the pump and tank. So I will assume that the only valve shown, is the one that shuts off the water into the tank, since the line goes into the lower section.
...but the NEXT question...how do I totally isolate the tank? I see no valve on the top line (output)....so if I use the pump to supply water from the fresh water tank to flush the commode, will it back flow some how into the ruptured hot water tank?
Thanks again for your input...
31' 1981 Excella II
or
Old 02-26-2014, 08:44 PM   #10
jcanavera's Avatar
Fenton , Missouri
Images: 143
If that valve in the picture shuts off the cold water supply to the hot water tank, you will be fine. Since the hot water tank sends water to the hot water lines in your trailer, if you cut off the (cold) water supply to the tank, the hot water lines will have no pressure. The water pump only pressurizes the cold water system. Hot water is pressurized from cold water entering into the hot water tank and there is only one way for cold water to flow into that tank.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-26-2014, 08:51 PM   #11
NevadaGeo's Avatar
Genoa , Nevada
I think that valve-line is the street water pressure line into the cold. The green hose from the pump also goes into the same cold line, but any valve on that isn't shown.
So you may be able to shut that valve shown and have street pressure water in the cold line but not be able to run the water pump. Doesn't help if you don't have street water.
oops, we never read the whole thing. You'll have to dump water into the commode using the lady's favorite water pitcher.
NevadaGeo
Old 02-26-2014, 10:48 PM   #12
ole81's Avatar
1981 31' Excella II
Richmond , Texas
saga continues.....
OK...I have finally analyzed the plumbing (which I should have done in the first place...) and find that there is a valve missing to keep the tank out of the system.
Since we are planning to install a new tank, I would appreciate if someone could point me to...or provide a good schematic of the preferable bypass system.
Also....am puzzled why our unit has both black and grey lines...is there a functional difference?
Did Airstream use both?
I have been told that I should use PEX lines to fabricate a new configuration.
What are your thoughts????
Bob and Gail
31' 1981 Excella II
or
Old 02-26-2014, 10:48 PM   #13
jcanavera's Avatar
Fenton , Missouri
Images: 143
Yikes! If that green is from the pump, then you are screwed. Obviously I'd do some changing of that water system once you replace that tank.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-26-2014, 11:04 PM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
Take a close look at post 6 and see how you can adapt that style. If you look closely the two valves, the lower one and the upper one, if you move to the right of those valves that piping terminates in the water heater. So the lower pipe is the cold water input, and the upper is the hot water pipe exiting the heater. So logically turning both valves off isolates the water heater completely from the cold and hot water pipes.
Now look to the left at that valve in the middle of the vertical pipe. That's the bypass valve. This pathway allows you to pressurize both the cold and hot water lines when the water heater input and output valves are closed. If you have this type of setup, you can winterize the lines easily since you can put air pressure in the cold and hot water side from your city water hookup. And in the case of a water heater breach, you can isolate that unit from your water system and still keep pressure in the lines. In your case since the toilet feeds from this area, you would need to move the feed for the toilet to the left side cold water pipe.
So what you need to do is look at your replacement water heater input and output and design the piping, keeping the concepts of that system that I posted within the pipes necessary to fit in the area available.
Jack
Jack Canavera
STL Mo.
AIR #56
electric water heater??? diggersanddo Water Heaters, Filters & Pumps 6 02-13-2014 04:04 PM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Toilet Fresh Water Valve Leak perryg114 Sinks, Showers & Toilets 7 10-11-2011 06:41 AM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
