Old 02-27-2014, 04:53 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by ole81 View Post
I appreciate all the input.
\Unfortunately, virtually all manuals are written by the engineers who develop the system, and are never reviewed by new users.
I think it's a safe bet that the plumbing system is a retrofit and not Airstream original so the manual wouldn't help you anyway. I say that because you do not have ball valves with lever, oval, or wingnut-style handles, where "handle in line with the pipe" equals on, and "handle crossways to the pipe" equals off, and all you need is a quarter-turn to go from fully open to fully closed. Instead you have a gate valve with a round handle, that you can't tell at a glance is open or closed, and requires several full turns to go from open to closed.
If you rework your plumbing system, use ball valves exclusively; get rid of the gate valves.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-03-2014, 06:50 PM   #16
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
The valves you show in the first post look just like the valves in my 1979 MH. I think they are original. The black tubing gets old and hard but it doesn't fail. The grey fittings got very brittle and one by one they failed. After several repairs I ended up replacing all the piping with pex. Keep an eye on those fittings, watch for leaks!
Gregsch is offline   Reply With Quote
Old 04-04-2014, 05:03 AM   #17
I stand corrected. Thank you. I personally think that ole81 would be well-served by replacing his valves with ball valves if he redoes his plumbing, just for ease of operation; there's a reason why they became standard on later-model RVs.
WBCCI #1105
TAC LA-4
Old 04-05-2014, 02:22 PM   #18
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Oooops!
I made a mistake.....
I removed the hoses from the 12v pump and some time later realized that one fitting appears to be a check valve....but did not note whether it was located at the inlet or outlet of the pump.
Any help would be appreciated.....
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 04-05-2014, 03:01 PM   #19
I believe the check valve is on the outlet side, installed so that water will flow out from the pump, but not back into it.
WBCCI #1105
TAC LA-4
Old 04-05-2014, 03:19 PM   #20
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Thanks for the prompt reply....
One more question....
I am using PEX. I have used the ss crimps on most of the fittings, and I know there are copper rings, compression and push together.
Has anyone found any negatives to simply using ss hose clamps and tighten them with a socket and ratchet?
We are not dealing with high pressures.
Bob and Gail
31' 1981 Excella II
or
electric water heater??? diggersanddo Water Heaters, Filters & Pumps 6 02-13-2014 04:04 PM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Toilet Fresh Water Valve Leak perryg114 Sinks, Showers & Toilets 7 10-11-2011 06:41 AM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
