Old 06-09-2015, 10:43 PM   #15
1977 31' Sovereign
Lynnwood , Washington
All I know is that the anodes I rotate in and out of my Atwood every 6 months sure take a beating. I can only imagine what my aluminum tank would look like without them.
Tom
TomKirk is offline   Reply With Quote
Old 06-12-2015, 07:21 AM   #16
1998 30' Excella 1000
Livingston , Texas
I'm on my third Atwood water heater after 18 years of full-timing. The first two (tanks) lasted a total of 15 years. When I replaced the first one, I saved the (expensive) circuit board. When I replaced the second one, I saved all the removable parts. I've since learned that you can purchase just the tank, and replacing it is only a little more difficult than doing the whole unit, and quite a bit cheaper. With my stock of spare parts, I'll just be replacing the tank next time.
Siegmann is offline   Reply With Quote
Old 06-12-2015, 07:48 AM   #17
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Fifteen years old and used a lot. Still has original water heater, a/c unit, refrigerator and microwave. Hate to go new. I think new fails more often, but then wouldn't an old fart think so?
mhilley is offline   Reply With Quote
Old 06-15-2015, 07:22 PM   #18
billiards's Avatar
rochester , Minnesota
post update on water heater.......removed old, measured calc. opening, I found opening was ALMOST large enough to force in the new.....BUT NOT QUITE....
I would post that b-4 the mistake to try and make it work......make a small cut ( dremel drill) down the bottom support frame and bend over the lip.....giving about 1/4 inch to allow the heater access....I also cut a channel for the wiring harness (about one inch) using same process at the lower right corner. Hope this helps someone some day.
billiards is offline   Reply With Quote
Atwood Water Heater Tank Life Siegmann General Appliance Topics 4 09-22-2014 10:33 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
COSTAR Carbon Monoxide alarm service life ostream Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-08-2010 07:11 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
