Old 09-30-2012, 07:49 PM   #1
Old School Young Gun
ElCamino Man's Avatar
Olney , Illinois
Water Heater Replacement
Hey guys! I got all the plumbing in my AS done (including water heater) to find out my water heater is gas... No problem, except my gas isnt hooked up. I was going to tear out all the gas lines and go to full electric before I found this out. My first thought was to replace the heater with an electric one. Do they make a camper specific one?
Option 2: Rip out all my gas lines EXCEPT the one going to the water heater and keep a gas water heater. Simple enough! Except Id have to keep tabs on my propane JUST for hot water.
Which is the better solution?
No Airstream Yet...
ElCamino Man is offline   Reply With Quote
Old 09-30-2012, 07:58 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Go with a unit which works on both electric and gas. When I replaced mine, that is what I used. When camping with full hookups, I use the electric. If I am dry camping, I use the gas. It works like a champ. Also, if all four of us want to shower in the morning, I use both for quick hot water recovery.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 09-30-2012, 07:59 PM   #3
cameront120's Avatar
1972 25' Tradewind
Put in an Atwood 10 gallon that runs on both gas and 110. It'll be an easy swap with the old one.
North Vancouver, BC
Old 10-01-2012, 07:54 AM   #4
Olney , Illinois
Gotcha! Thanks for the input guys!
No Airstream Yet...
Old 10-27-2012, 10:53 AM   #5
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
is changing easy
I am currently camping and the water heater has gone out several times. The pilot light is very low and easy blown out. I put a new pilot assembly and didn't improve. I can spend over a hundred dollar on a new valve or put that money on a new unit with electronic ignition. On my 1976 will the old one pull out the hole from the outside and will the new one fit the hole with out major modifications. Any ideas? Thanks
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
GAT is offline   Reply With Quote
Old 10-27-2012, 02:10 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Gene!
I suspect that you coach likely cam equipped from the factory with a 10-gallon water heater. A typical six-gallon RV water heater will require modification to the opening. Ten-gallon modern RV water heaters "may" be a very close replacement for an OEM 10-gallon unit, and this can be verified by comparing the opening measurements for the new unit against the opening in your coach.
My '78 Minuet had an OEM six-gallon water heater, and a new Atwood six-gallon water heater fit in the opening without modification.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-27-2012, 04:55 PM   #7
Splitrock's Avatar
Sioux Falls , South Dakota
Hi Gene,
I replaced my water heater with an Atwood 6 gallon gas/120 volt electric. I had to raise it up a little. It was an easy install because I had the toilet and the bathroom walls removed at the time. I added a water heater install section to my blog. That shows what I did.
Old 10-27-2012, 05:38 PM   #8
Ottawa , ON
Any ideas? Thanks
Before you spend the big bucks, change the thermocouple. It's the tube that the pilot bathes in flame, and if it isn't in good shape, the furnace won't work properly.
It's a disposable,like the pilot assembly: not expensive.
Old 10-27-2012, 05:49 PM   #9
87MH's Avatar
1978 31' Sovereign
Images: 292
How many amps will be available to the trailer?
Originally Posted by ElCamino Man View Post
Hey guys! I got all the plumbing in my AS done (including water heater) to find out my water heater is gas... No problem... I was going to tear out all the gas lines and go to full electric before I found this out. My first thought was to replace the heater with an electric one.
Do you plan to install a 50 amp service???
I ask this because I am certain that most Electric Water Heaters will draw around 15 amps. The draw of an Air Conditioner at startup could easily approach 20 amps - you would have to do some powerful amperage control if you intend to use a cooking element or microwave in addition to the usual light and entertainment draws.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
