Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-07-2006, 10:07 PM   #1
Wayne Gilley
Profile:
Water Heater Replacement on a 75 center bath
Waht has to be removed to get to the back of the water heater. There is a small access under the sink but not large enough for me to get to the pipes.
This looks to be a larger project than it should be. Any insight would be helpful.
Wayne Gilley is offline   Reply With Quote
Old 06-07-2006, 10:50 PM   #2
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
go look at http://www.airforums.com/forum...ign-23313.html and you can see what it looks like once you take the cabinet apart (my cabinet is remaining apart--new birch plywood on its way).
You will have to remove some rivets on the skirt that is to the outside (toward the curb, oh my gosh, your bath is on the curb side, isn't it? if not, reverse my directions, as required) of the toilet and under the shelf under the basin. Take that skirt out. Undo the two compression fittings. Go outside and take out the 12 screws around the perimeter of the water heater. Undo the propane line and either slide it down into the floor (from the outside) or cut off the flare nut as close to the nut as possible then slide it down.
The water heater should now pull cleanly out of the opening, with only a little sticky from the plumber's putty around the opening. Putting a new one back is a 1-hr job.
I recommend you paint the floor with an oil/alkyd based paint before you put a new water heater back in.
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 06-11-2006, 11:11 AM   #3
Wayne Gilley
Profile:
Great pic's thanks this should help..
Inside hot water heater cover davidz71 Water Heaters, Filters & Pumps 12 03-24-2008 09:11 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 10:15 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 11:18 AM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 04:58 PM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 11:57 AM
