Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-26-2002, 11:27 AM   #29
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Putty
Yup. That's the stuff. Mine came in light grey. The stuff is a bit tougher than vulkem, so it forms a strong but flexible seal between the outside flange of the water heater and the aluminum of the Airstream.
I've got most of the roll left. e-mail me your address, and I'll mail it to you today.
uwe@salwender.com
Cheers!
Uwe
Old 11-24-2005, 11:42 AM   #30
tom3061
Profile:  1961 30' Sovereign
st paul , Minnesota
hex Ijhave recently purchased a 6l and was told there was a soft spot in the floor by th window the previous owner thought it was from the window. But it was from the hot water heater, I ended up removing about 4ft x 1ft of floor from the window back under the hot water heater. Be sure and check the floor after you remove the hot water heater. Tom 30 61
tom3061 is offline   Reply With Quote
Old 01-03-2006, 08:42 PM   #31
teemack
Profile:
I have a 1974 0verlander that I thought about installing a hottrod. the drain plug is 1/4 inch pipe with 20 threads per inch. The hottrodd is 3/8 inch pipe with 13 theads per inch. I can drill out the 1/4 inch bushing and retap using the 3/8 inch with 13 threads per inch. Before I do this, someone please tell me why I don't want to.
teemack is offline   Reply With Quote
Old 01-03-2006, 08:49 PM   #32
markdoane
Profile:  , Minnesota
Images: 59
teemack,
Is it 1/4" pipe, or 20 threads per inch. It can't be both. Be sure you have the correct taps before you try this. If you tap it 3/8-13 you won't ever get a 3/8" NPT fitting to go into it.
Are you sure the hotrod is 3/8-13, because that isn't a pipe thread, it's a machine thread.
Non-contributing deadbeat.
Old 01-03-2006, 08:58 PM   #33
teemack
Profile:
maybe it is 1/4 by 20 threads on the drain plug, and the hottrod i was told was 3/8 inch pipe, with 13 tpi. are you telling me that it might possibly be 3/8 inch with 13tpi flare threads?
Old 01-03-2006, 09:44 PM   #34
markdoane
Images: 59
No, I'm saying that 3/8" NPT pipe thread is 18 tpi, not 13 tpi. 3/8-13 NC is a screw thread, not a pipe thread.
I don't remember the threads on a flare fitting.
The best bet would be wait until you have the hotrod in your hands, measure it with a thread gauge, then tap the bushing. I wouldn't trust what someone tells you over the phone in a case like this.
Before you order it, see if the bushing is big enough to take a 3/8" pipe thread, it's a lot larger than a screw thread. 3/8 inch pipe is just a little less than 3/4" (actual .675") in diameter.
Old 01-08-2006, 09:08 PM   #35
teemack
Profile:
well, i just got up from my chair with lights, and a pair of reading glasses. The drain plug is a 1/8 inch pipe threads, with 27 threads per inch. The hott rod is 1/4 inch pipe threads. The solution is the predrill the drain with a 7/16 inch bit, and retap to the 1/4 inch pipe threads. Or, just put everything back together and wait until the 30 year old unit goes out completely.
Old 06-18-2007, 07:47 AM   #36
dikku
Profile:  1992 21' Sovereign
ft mitchell , Kentucky
I need to install a new water heater in my trailer pronto. Does anyone know a sealer I can buy at Lowe's or HOme Depot that will do the job?
dik
dikku is offline   Reply With Quote
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
Water Heater Replacement (help) rdm General Motorhome Topics 1 07-14-2003 03:31 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
Hot Water Heater Replacement rpwx Water Heaters, Filters & Pumps 0 08-25-2002 08:44 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 04:53 PM
