Old 03-14-2016, 02:23 PM   #1
1981 31' Excella II
Glendale , Arizona
Water Heater Replacement
I have a 1981 Excella II (side bath/rear bed), and I'd like to replace the water heater with a new one. Do I just remove everything from the outside, or are there connections that I need to get to inside the trailer? I can't see any way I'd access the rear of the water heater inside the trailer if there is.
I have an Atwood-Bowen and the manual indicates a 6 gallon unit with remote ignition.
Also open to suggestions on what to replace it with.
Thanks!
az_streamer is offline   Reply With Quote
Old 03-14-2016, 03:37 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You will have to brake the 2 water connections on the back of the heater. It may be easier to just cut the piping where you can reach and splice after the new install. The trailer body was installed after the heater was and thus you may have to cut the shell a bit to get the heater out to allow for the insulation to pass through the opening.
2004 Excursion 4x4
Old 08-19-2016, 06:21 PM   #3
1981 31' Excella II
Glendale , Arizona
That makes sense. Thank you.
Old 08-19-2016, 09:13 PM   #4
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
We've been satisfied with the Atwood 6 gal remote spark gas only we put in our 64' Safari about 10 years ago. Enough so, we just put the same thing in our current project.
You may need to base your decision on the dimensions available after you've excavated the original.
Good luck,
Roy
64airstream is offline   Reply With Quote
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 09:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 09:06 PM
