Old 08-01-2005, 08:30 PM   #1
Thumbs up Water heater repair
I took advantage of the extra time off this long week-end to finally test my water system. I was a little sceptical that the PO had winterized it right, and in anticipation of leaks I had been waiting until I had the old carpet out to run the water. Well the good news is the fresh water holding tank holds water, the pump pumps quite nicely and all the pipes seem to be leak free (amazing). Big bad news arrived in the form of a large puddle forming around the water heater. I yanked the heater out, and confirmed my suspicions about the PO's winterizing abilities. The hot water tank had a nice, big split in the bottom from being frozen. I'd rather not part with the $ for a new water heater if I don't have to, especially since the PO had a new control module and igniter installed in this one last summer. The split in the aluminum tank can be tig welded no problem, but I was wondering what internal damage there may be to the heat exchanger (if any). Any one know what these things look like on the inside or what the contruction of the heat exchanger is? I'm assuming that once it's welded if it'll hold air pressure I should be good to go. Has anyone else run into this problem and been successful in repairing it? P.
Peter&Denise is offline   Reply With Quote
Old 08-02-2005, 07:37 PM   #2
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Peter,
Several years ago I needed to replace the tank in my Argosy, which had a Bowen water heater, and I mentioned it to the parts guy at Three-way Campers in Atlanta. He told me to hang on, escused himself, and walked back a minute later with a brand-new tank. I bought it for $20. I suggest that you check around at your local RV dealers. They might just have what you need sitting around, and new old stock beats repaired most times.
Good luck. Lamar
SafeHarbor is offline   Reply With Quote
Old 08-02-2005, 09:00 PM   #3
I wish it were that easy! I have not seen any parts breakdown for the Attwood heater that I have which shows the tank and heat exchanger being available "blank". Were that the case, I would gladly swap out all my propane and electrical riggin' to a new tank. Thanks for the suggestion tho'.
I'm surprised that no-one else on this forum has attempted such a repair, or at least cut apart one of these suckers to see what they look like on the inside. I can assure you that if I can't fix mine I'll salvage what I can and the rest will be going under the sawsall just so I can have a look-see on the inside before it goes to the dump. Inquiring minds eh? P.
Old 08-03-2005, 07:29 AM   #4
sovereignrwe's Avatar
2020 30' Flying Cloud
1995 25' Excella
Clear Lake , Minnesota
Either Peter is an engineer, or one in training...
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-03-2005, 06:16 PM   #5
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
He wouldn't have a sawsall if he didn't like to cut up . . . things!
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
Old 08-03-2005, 10:00 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Here is a site that sells Atwood tanks, without the electronics. You might check with them to see if they can fix you up.
http://www.marksrv.com/atwoodtanks.htm
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-04-2005, 07:25 AM   #7
Thanks for the link! If the tank repair doesn't pan out, I'll definitely order one from those guys. P.
Old 08-04-2005, 08:25 AM   #8
jaiman's Avatar
Images: 32
Be sure to inspect the exhaust area of your used tank. I was going to repair mine after the "C.O." current owner......me, didnt winterize it properly and it split the aluminum. Doh! I noticed alot of corrosion in the exhaust that could have potentially leaked carbon monoxide back into the living area. I tossed it and bought a new one.
Jai
jaiman is offline   Reply With Quote
Old 08-04-2005, 12:08 PM   #9
My Atwood aluminum tank had a defective weld on the water outlet that only showed up after 17 years. I had a local machine shop weld it at a cost of $15 or so.
Mark
'85 Sovereign, 25'
j54mark is offline   Reply With Quote
Old 08-04-2005, 12:23 PM   #10
No corrosion, so I'm holding out hope that the repair will be successful. Before we button it back up I'm going to get a look inside with a fibre optic scope, just to see if the heat-exchanger suffered any freeze damage. With luck I'll have hot water by the week-end. P.
Old 08-04-2005, 03:30 PM   #11
1995 25' Excella
<---- jealous of Peter's toys
Mark
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
