Hot water heater is failing?
Looking into replacing it but I got the same problem as most of you guys. I dont see how its going to slide out as I have the decorative band going over the bottom edge of the heater.
Dismanteling it from inside seems to be an outrageous job.
I live full time in my airtsream so I need to fix this problem quiiiiickly ;-)
Heeeelp.
The unit works for just a little bit but then gas starts spurting in and out then unit quits. Would it be the regulator or can I just change the small tub with the air slider instead of changing the whole thing? and if I have to change the whole thing which Atwood model do you recommand for this airstream, I can't see any where if its a 6 or 10 gals.
Thank you for your inputs.
1972 overlander 27'
Santa Rosa, CA
Elizabeth
