Old 02-21-2011, 04:02 PM   #1
Ag'71's Avatar
1971 27' Overlander
Springfield , Missouri
Water Heater Removal
My water heater is dead and I need to replace it. As I look to remove the old one, the two inch aluminum trim covers the bottom screws, keeping me from getting it out. Do you recommend cutting the trim on either side of the water heater, then removing the screws and extracting the unit? I don't want to remove the trim half way around the trailer just to get the unit out. Any suggestions? Thanks!
Ag'71 is offline   Reply With Quote
Old 02-21-2011, 04:25 PM   #2
North Las Vegas , Nevada
I don't know what I'm talking about, but don't let that scare you. There's an Airstream restoration series on youtube, and they cover the replacement of all the appliances.
Also, there's this thread on the airstreamcentral website
http://www.airstreamcentral.com/arti...not/Page1.html
Good luck and let us know if this helped. I'm sure I have it in my future.
Maynard is offline   Reply With Quote
Old 02-21-2011, 05:40 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
My trailer is a 1976 31' Sovereign. I removed the lower belt trim to remove the old heater.
Old 02-21-2011, 05:53 PM   #4
cameront120's Avatar
1972 25' Tradewind
Just pop a rivet or two from the trim so you can lift it enough to get at the screws. No need to cut the trim or remove it completely.
North Vancouver, BC
Atwood water heater burnt wire richinny Water Heaters, Filters & Pumps 5 06-21-2011 08:27 AM
Electrical? Water heater? Water pump? robwok 1960 - 1964 Overlander 6 02-09-2011 12:53 PM
Furnace and Hot water heater complete Airdaddy Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-02-2011 10:16 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
