02-14-2015, 11:30 AM
1977 23' Safari
Carberry
, Manitoba
Water Heater reinstall
I am reinstalling my water heater after removing it to repair floors and redo plumbing. When I removed it, there appeared to be a thin fibre? gasket between the flange on the heater and the aluminum skin of the trailer. What was its purpose and when i reinstall should I be replacing that gasket with a new one? If so, what sort of material should I use? thin closed cell foam?
02-14-2015, 11:55 AM
King of the Zebra Speedo
Obrien
It's purpose was to keep water out... I just used Vulkem for a sealant when I replaced mine. If you want to go back with the gasket, I can't find one using the googles, but I'm thinking a closed cell foam ought to work.
-Red, 2 years and still holding...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
02-14-2015, 12:02 PM
1977 23' Safari
Carberry
, Manitoba
thanks Red, I can't get vulkem around here but I have been using a polyurethane caulk that is prbly similar. Unless I find a piece of thin foam handy I'll likely just go with caulk.
Lorry
02-14-2015, 01:41 PM
1998 30' Excella 1000
Livingston
Two words... putty tape (even better, butyl tape, if you can find it). I know, that's more than two words.
02-14-2015, 03:56 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
putty tape the flange, then caulk too.
Alan
02-14-2015, 04:12 PM
1994 34' Excella
Warren
, Manitoba
I use a product from Wearing Williams in Winnipeg, and used in the bus building industry. It is made by Bostik, Simson 70-03 is the product. Recomended in place of Vulkem and have used with excellent results for several years. Easiest product for availability in Manitoba.
Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
02-14-2015, 04:53 PM
Ottawa
, ON
Fastenal is where you get TremPro 626
Just FYI: Vulkem is now called TremPro, and is sold in all Fastenal stores. If they don't have it in stock they can order it in within a few days. This goes for Canada and the US.
There are many colours and consistencies of TremPro. 626 is a grey colour, and seems to be the version of choice for us AS trailerites.
It is manufactured by Tremco Inc.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
02-14-2015, 04:58 PM
1969 23' Safari
Blenheim
, Ontario
And make sure you give the stainless screws/ olympic rivets some sealant as well!
