11-18-2017, 05:21 AM
2006 19' Safari SE
Hayes
, Virginia
Water heater red light
My water heater on my 2006 19’ Bambi, the red light remains on. Turn on gas, turn on red light switch, and she stays on on. I know this has been asked before but I cannot find it. She was working great until our last camping trip, then this problem. Appreciate any help. Thank you. Tom
11-18-2017, 05:28 AM
Normal
Is your water heater lighting, or is it just the red light staying on that bothers you?
Maggie
11-18-2017, 05:40 AM
2017 28' International
Virginia Beach
, Virginia
I just went through this with my 2017 Serenity. Turns out it was the circuit board. It was not generating enough power to spark the igniter. Easily replaced.
11-18-2017, 06:17 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
If the red light on the water heater switch stays on, it means that the there is a problem, and the unit is not lighting. Many times it is a problem with the electrics. The first thing that I would try is removing the bayonet connectors and cleaning the contacts. You can do this by pushing them on and off several times.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-18-2017, 08:53 AM
2006 19' Safari SE
Hayes
, Virginia
Water heater redlight
Guess I left one important statement out...The light stays on, she ignites and sounds good, but....ya might get a quart of warm water and that is it....I have a good blue flame...
11-18-2017, 08:58 AM
2002 30' Classic S/O
Fleming Island
If you haven't changed anything since the time it worked, it may be the overtemp sensor. Are you sure the air has been flushed out of the heater?
Al
Mantua
, Ohio
It's waterlogged. It needs the air bubble renewed.
11-18-2017, 09:10 AM
Normal
That’s good information to provide, gives the situation a whole new look.
Maggie
11-18-2017, 09:28 AM
2006 19' Safari SE
Hayes
, Virginia
Just cleaned contacts/connectors with contacteen(sp), slid them in/out, flipped switch and still getting picture-perfect flame and light stays on. Everything gas is working except red light on heater....
11-18-2017, 09:38 AM
2006 19' Safari SE
Hayes
, Virginia
Al
Is the over temp sensor the round thermostat? I can change that easy enough
11-18-2017, 09:39 AM
Tampa
That would make me worry there's no water in the tank.
11-18-2017, 11:12 AM
2006 19' Safari SE
Hayes
, Virginia
I just drained it yesterday when I was monkeying around with it. And like I say, I turned on the hot water valve and let it run just to make sure.
11-18-2017, 11:40 AM
2022 25' Flying Cloud
NCR
, Ontario
same issue
it was a bad circuit board.
i'm now waiting 7 weeks to get a wuarantee refund from the water heater OEM
11-18-2017, 11:42 AM
Fleming Island
If yours is like mine, there are two, one is the normal thermostat, the other is the emergency cutoff.
Without knowing your particular heater, I can't say. I bought a service kit on Amazon and it had both.
You may find this useful:
http://manuals.adventurerv.net/Atwoo...nuals-2007.pdf
Al
11-18-2017, 04:56 PM
2012 23' FB International
Woodstock
, Ontario
Over temp T'stat cycles on and off, unless they have changed the operation; it does not open and stay that way. You just get really hot water. The operating and over temp T'stats are wired in series so the controller doen't see the difference at least on older As models
OP discovered what I thought was the problem....faulty board, but at least he got hot water. Occasionally a heater board problem is just a bad ground...something the owner's manual says to check be fore replacing the board.
JCW
11-19-2017, 06:42 AM
2006 19' Safari SE
Hayes
, Virginia
Thank you, mine is just like that. Camper sales up the road so, will get those two things in the morning. Thanks all for the assist........
03-04-2019, 11:16 PM
2016 23' Flying Cloud
Eugene
, Oregon
Hi-I don't think this issue is covered. I recently got the trailer, never used the gas heating option. When leaving the electric heat option on, it heats the water and then the red light comes on? then I turn off the electric water heater button- after a while I turn it on again, heats the water and red light comes on and stays on.
ideas? thanks
03-05-2019, 01:04 PM
2017 27' Flying Cloud
Fort Worth
ideas? thanks
The red light is an error. That light is not suppose to come on.
