Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-20-2006, 07:14 AM   #1
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Water heater rapid cycling on/off
We have a propane only DSI water heater that has started cycling on/off constantly (even with no water being used). Water is plenty hot, and there is more than enough to shower. Plenty of propane in the tanks, all other appliances run well so I am assuming pressure is ok.
Any ideas what causes this and how to fix?
Thanx, Bill
BillTex is offline   Reply With Quote
Old 06-20-2006, 07:45 AM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Thanx, Bill
Bill,
It's hard to say without being there, but start with checking and cleaning the LP supply lines to the burner, the burner itself and the burner orifice. Any blockage there could be the cause. Of course, there is always the igniter board. They bite the dust on a regular basis and need replacing. If it is the board (any equipped RV shop can test it for you) you should replace it with a Dinosaur Electronics board. 3 year warranty and the boards are built so space program specs (without the government contract prices ).
Also, check your ECO and t/stat. The 12VDC runs thru them in a circuit loop and one of them might be bad as well, causing your cycling problem.
Keep us posted on your results and progress! Good luck.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-26-2006, 02:51 PM   #3
BillTex
1 Rivet Short
Update
Well we had another rain filled weekend here in New England...so I had the time to look at the water heater. Cleaned out the tube, checked all the clearances, and fired it up. Everything looks fine, did not cycle like it was before...maybe I fixed it?!
Thanx Lewster
Old 07-12-2006, 06:54 PM   #4
BillTex
1 Rivet Short
Need more water heater help
Had a good trip last weekend but still had water heater trouble. It appears that the terminal on the "blue box" at the bottom of the Atwood heater (see pic) is loose and may be on the way out. I stipped back the red wire from the ECO and clamped a new terminal plug on there, and that seems fine. When I jiggle the terminal on the blue block it runs better, doesn't sputter. So I believe it is the blue box and not the wire.
What is the blue box and where do I get one?
Please see bottom of picture.
Thanx, Bill
Name:	Water heater 001 (Small).jpg
Old 07-12-2006, 09:20 PM   #5
BigAl
Profile:  1994 30' Excella
Mississauga , Ontario
Looks like the gas valve to me!
Al
Old 07-13-2006, 12:29 AM   #6
lewster
Commercial Vendor
lewster's Avatar
Those are the solenoids (2 of them in redundant series connection for safety) that open and close the gas valve above them. You probably need to replace the entire gas valve as I haven't seen the solenoids available separately lately.
Any good RV parts place should have them. If you have trouble finding one, PM me and I'll get it for you.
AIR # 10325
Old 07-13-2006, 07:02 AM   #7
BillTex
1 Rivet Short
This looks a little different than whet I have?
Should it work?
http://www.campingworld.com/browse/s...15255&src=SRQB
Thanx, Bill
Old 07-13-2006, 11:40 AM   #8
lewster
Commercial Vendor
lewster's Avatar
There are several different designs from a few manufacturers out there. I would call CW (if that is where you will buy it) and give them the model # of your heater and ask them if it will fit properly. You can sometimes shoe-horn them in, but I don't do this when working with LP gas! You really want the OEM part that fits your heater.
AIR # 10325
Old 07-13-2006, 12:50 PM   #9
BillTex
1 Rivet Short
I couldn't agree more-but where do I get an OEM Atwood valve?
The heater is model # G6A-6E DIS, I beleive original-1989.
Thanx, Bill
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 06:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 11:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 11:57 AM
