Old 10-23-2011, 01:27 PM   #1
2007 19' Safari
lakeville , Minnesota
Water heater quits running
I have an atwood water heater in my 2007 19' safari after not using for a week or more when I start it it shuts down after about 10 minutes. After restarting a number of times it will finally kick in and run without problem. Anyway to get it to work correctly on first try?
2007 safari is offline   Reply With Quote
Old 10-23-2011, 03:05 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Could be one of 3 things:
Thermostat
ECO (energy cut-off, the little thing with the bent wire encased in a plastic tube)
Igniter board.
Difficult to say without being there when it fails.
At the failure point, test for continuity at the ECO and t/stat. If they are both OK, it's the igniter board. Replace with a Dinosaur UIB-S board and you're good to go.
Old 10-23-2011, 04:40 PM   #3
2012 25' FB International
Evanston , Illinois
We had the same problem. It turned out that the connector that attached several wires to the circuit board was loose. I simply unplugged the connector from the board and replugged it. Problem solved!!!
Hi-Ho Silver!!
JerryMcMunn is offline   Reply With Quote
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
