Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-25-2006, 09:00 PM   #1
Profile:  Plantersville , Texas
Water Heater Quit again
My water heater worked for several days and now it has quit again. I have no voltage to any of the controls. I have 13.5 v at all the fuses in the dcv panel. The switch would light up for an instant but now no light at all. I am wondering if the switch is bad. I took it loose from the wall and didn't know how to test it. ( I didn't take the wires off )
I talked to 2 rv parts stores and they both wanted the model #. I can't find a model #. It is in my 83 MH and is an Atwood with the electronic ignition
Any ideas would be great. Thanks
Kay
carnegie1935 is offline   Reply With Quote
Old 08-25-2006, 09:14 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
The model number should be on a tag glued to the inside of the ware heater, inside the outer cover (where the burner is).
As far as the problem, you may have a bad board, but it would be a good idea to check it out before jumping the gun, getting one, and finding out you have a bad ground somwhere.
(No Longer at Inland RV)
Old 08-26-2006, 08:18 AM   #3
Tag is gone on outside I may have a bad ground but so far I can't find it. The circuit board is new . I know new can fail. I don't know how to check any further.
Kay
Old 08-26-2006, 08:26 AM   #4
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
My Atwood with DSI would only ignite intermittently. I couldn't isolate the problem myself, but after calling Mark's RV mail order and explaining the problem, he said it was the board. I purchased a Dinosaur Electronics aftermarket board that had a better warranty and was significantly less $$ than the OEM. It's been working great. Again, not sure what is wrong with your heater, and I wouldn't suggest throwing $$ at the board unless you're fairly confident that's where the problem is.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 08-26-2006, 09:29 AM   #5
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Kay
kay
look for a green wire attached to the ignitor case.
here is my fix http://www.airforums.com/forum...und-12125.html?
john
you call them ferrets, i call them weasels.
Old 03-20-2007, 06:56 PM   #6
Profile:  1987 29' Sovereign
1971 21' Globetrotter
glen carbon , Illinois
I have the same problem replaced the board with the dinosaur board replaced the ignitor and checked the thermo and high temp switch all check ok when I hit the switch. red light comes on no spark.??????
silverflash is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
