Old 07-09-2011, 07:44 PM   #1
BLUEBELL
BLUEBELL's Avatar
2007 25' Safari FB SE
MACON , Missouri
Water heater problems
We have a 2007 Safari and have been having problems getting the water heater to light. When we turn the switch on it clicks, but won't light. We can light it by hand and it will stay. We have had the board changed because we were told this was the problem. It worked fine for a couple days, but now we are right back to the same problem.
BLUEBELL is offline   Reply With Quote
Old 07-10-2011, 06:14 PM   #2
2005 19' Safari
GLENDALE , AZ
I don't know if this will work for you, but our hot water heater has trouble staying lit when we first use it after the trailer has set for some time. It spits and sputters, and goes out. It takes a little time for propane from the tank to purge the air out of the line, and the water heater is the furthest appliance from the tanks (on our 19-foot Bambi). We just turn the wall switch off for a couple of seconds and turn it back on again. After a couple of cycles like this, the propane has made it to the hot water heater and it will stay lit. This also seems to help the refrigerator start and stay on (when using propane). I never checked the propane lines to see how they are routed, but it seems like if we light the stove first, we have less problems; although this may just be coincidence.
If you are in the mountains and the tank you are using isn't full, you might try switching to a full tank. It seems like more pressure helps, too. This also works in subfreezing weather, when the propane tank pressure drops due to the cold outside temperature (even more of the problems in subfreezing weather in the mountains).
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 10:07 AM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
