Old 01-08-2015, 07:42 AM   #1
1993 34' Excella
Yalaha , Florida
water heater pressure valve
I have a 1993, 34' Excella and the water heater is heating up to the point of opening the pressure release valve. When the water comes out of the valve it is hot, but not as hot as I would think, but the sink water is extremely hot at this point. Has anyone had this problem?
stuart.force is offline   Reply With Quote
Old 01-08-2015, 06:38 PM   #2
1998 30' Excella 1000
Livingston , Texas
Have you re-established the air space (for expansion) in the top of the tank?
Siegmann is offline   Reply With Quote
Old 01-08-2015, 08:13 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The water heater air space is needed as a "cushion" to take up the expansion of the heating water. Or it will find a place to force it's way out, the weakest point in the system. Sounds like your weak point is the pressure relief valve, which is the way it is supposed to work. But you still need to re-establish the the air space.
Turn off city water supply and the water pump. Turn off the water heater until it cools so you don't get scalded. Open a faucet nearest the water heater hot water and leave open. Go out and lift the pressure relief valve tab and let the water drain from the top of the water heater, while the open faucet will allow air in to replace it. When it is done draining (only a minute, give or take) let the pressure relief tab snap back in place, and go in and shut off the faucet. You should have an air cushion back in the water heater.
Note. This air cushion can be lost often, not the world's greatest invention, and may need to be re-established often. I put a small water pressure accumulator from Camping World in the bathroom faucet cold water line supply line of mine to help, and it does. Must be installed in a cold water line.
Doug and Cheryl
Old 01-08-2015, 08:17 PM   #4
dkottum's Avatar
Here's the accumulator.
Doug and Cheryl
Replaced city water SHURflo pressure relief valve fitting silverback Fresh Water Systems 3 06-01-2010 01:32 PM
Water heater pressure relief valve woliners Water Heaters, Filters & Pumps 6 07-10-2008 07:12 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
