Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-07-2008, 09:07 AM   #1
1965 28' Ambassador
Minnetonka , Minnesota
Water heater pressure relief valve
So my old Bowen water heater works great. Haven't observed the problems seen in other posts. However, I noticed the pressure relief valve was leaking around the little handle thingy. I reached in and jiggled it a bit and the handle came right out. Pretty rotted. It really leaked then as one would expect. Well I got the valve system removed without any issues, but I noticed that there is another pressure relief valve at the pipe exit underneath the camper body.
What's that all about. Do I really need 2 valves in series like that or did someone have too many pressure relief valved laying around the garage??
next question: Are these "special" valves or can you get them anywhere?
Bill
woliners is offline   Reply With Quote
Old 07-07-2008, 02:01 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Yes, and maybe
Originally Posted by woliners View Post
... I noticed that there is another pressure relief valve at the pipe exit underneath the camper body.
What's that all about. Do I really need 2 valves in series like that ... ?
next question: Are these "special" valves or can you get them anywhere? ...
The relief valve on the water heater is designed to pop open at a certain pressure OR a certain temperature. The settings are usually 150 psig or 210 degF. Plumbing code mandates that valve has to be there.
My '67 Overlander has a pressure relief valve on the cold water line (probably the other relief valve you noticed). At first, I considered it's presence the mark of superior design .i.e. one could do without it, but on occasion it might be useful.
But, I noticed that valve dribbles a little bit when water is heating (heating water raises the pressure in the line). So the valve serves a constantly useful purpose.
Airstream used a cold water relief valve rated to vent at (IIRC) 60 psig. Hardware store models are rated at 90 psig. InlandRV sells an Airstream-approved cold-water replacement.
I think you should keep both relief valves.
Tom
Old 07-08-2008, 08:58 AM   #3
1965 28' Ambassador
Hi Tom, Thanks for the reply. Actually, the second valve is attached to the end of the pipe coming out of the first valve. (they're in series) The exit pipe from the first water heater valve is routed out the bottom of the camper. Attached to the end of this pipe is another pressure relief valve.....sticking out the bottom of the camper and that's where it terminates. I don't have any attached to the cold water pipes....I should probably install one.
Old 07-08-2008, 11:03 AM   #4
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I had the same question a while back, the thread is below...
I have the same set-up as you - you'll see in my thread (IIRC) that there was some confusion about what valve I was talking about.
Replace the valve that broke, leave the other one.
Dave
http://www.airforums.com/forums/f445...lve-28019.html
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 07-09-2008, 07:33 AM   #5
1965 28' Ambassador
Thanks Dave,
I think I'll do that....why tempt fate. By the way, both valves are shot. The little manual lever just popped out of both of them.....and they both ooooz a steady stream.
Old 07-09-2008, 09:50 AM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I can't see any justification for a second valve in series with the water heater safety valve. It's one more thing that can stick and over-pressure the heater. It can also mask a failure of the first valve. If you think AS put it there, ask them why.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-10-2008, 07:12 AM   #7
1965 28' Ambassador
Thanks to everyone
Hey Everybody,
Thanks for the input. Lotsa good discussion. I've run the thing for a few days now and everything checks out. I probably won't max out the temp setting on the heater just to leave a little buffer there as well. I'll keep an eye on it. If anything big happens.....I'l let ya know.
Bill
pressure relief ? again twiggy137 Plumbing - Systems & Fixtures 3 05-15-2008 07:36 PM
pressure relief valve twiggy137 Plumbing - Systems & Fixtures 10 05-13-2008 08:20 AM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 02:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
