03-05-2019, 06:31 PM
2019 16' Sport
Vancouver
, British Columbia
Water heater plug left in after winterizing
I, through a brain cramp, put the drain plug back in my water heater after bypassing and winterizing. I don’t know if this would cause damage, I realized this and removed it, it was pressurized when I pulled the plug, there was just a little ice in the plug (it was well drained during winterization). Has anyone done something so stupid, if so could this cause damage?
03-05-2019, 06:34 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
If your water heater is an Atwood/Dometic, you have caused no damage. There is always some liquid left in the bottom of the tank. Since the tank is rounded the freezing liquid cannot create enough force against the sides of the tank to damage anything.
ps:
You can read this in the owners manual in the winterizing section. Here is a link:
https://www.dometic.com/assets/44/89...9.pdf?att=true
Alan
03-05-2019, 06:47 PM
2022 25' Flying Cloud
NCR
, Ontario
not a problem, no need to fret.
as long as you got most of the water out, the small renaming bit is no issue.
the freezing issue is when most of a volume, pipe, tank etc is water, then the freezing expansion WILL be a problem.
03-05-2019, 06:54 PM
2019 16' Sport
Vancouver
, British Columbia
Thanks for the quick responses
What a great thing this forum is, I will sleep better tonight!!
03-05-2019, 06:55 PM
2019 30' International
Pennsylvania
, Pennsylvania
I drain the water heater, flush it good with hose attachment designed for this purpose, then hand siphon as much water out as possible, then replace plug.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
03-06-2019, 06:53 AM
Sharon Springs
, NY
I was always one to drain the hot water tank, winterize and leave the drain plug out. That is, until a friend of mine got his trailer ready for the season and had an awful smell when running his hot water. He drained his hot water tank again and what was left of a dead mouse came out. Not sure how it could've got there other than through the open drain. We could put a peppermint "mouse away" pac, which works well in our trailer, but leaving our drain plug in for the past few years has not damaged anything. We live in upstate New York where gets cold and mice abound!! Good luck and safe travels, Jim
03-06-2019, 08:07 AM
2013 31' Classic
billings
, Montana
No problems...lol
03-06-2019, 09:04 AM
Sag Harbor
, New York
ps:
Exactly. Most folks way overthink this IMO.
Most Airstream owner's manuals also mention, where applicable, that you can drain the water heater out of its drain hole, and leave the remaining water inside. No need to blow out that small amount of water with compressed air.
The bottoms of most water heaters are shaped like a mixing bowl. Take a sturdy round-bottom stainless steel mixing bowl, put a quart of water in it, and put it in the freezer overnight.
Bowl OK!
Peter
