Old 07-13-2003, 08:16 AM   #1
Marko69AS's Avatar
Question Water heater pilot issues?
I seem to have some issues with keeping my pilot lit. The unit lights ok, but frequently extinguishes itself after heating the water tank. I have checked and adjusted both the pilot flame and air shutter adjustment...both appear to be correct but still don't like to consistantly work unattended.
The unit appears to be the original equip. (I am the second owner, and the AS was always serviced by dealer) Bowen heater and Robertshaw control, but I'm reluctant to R&R if all I need is a cleaning, etc.
Thanks in advance
Marko69AS is offline   Reply With Quote
Old 07-13-2003, 08:35 AM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Possibly
Sometimes the pilot flame gets pulled off the thermocouple. This may happen right when the water gets hot and the main jet goes off. On a prior trailer, I had to bend the thermocouple bracket a bit to keep it in the pilot flame when this happened. I had a similar problem with a prior refrigerator where the flame wasn't quite on the thermocouple at all times.
John W. Irwin
WBCCI #9632
Old 07-13-2003, 08:54 AM   #3
Marko69AS's Avatar
Wow! thanks for the prompt reply!
At the risk of sounding ignorant (a risk I hope I don't run too often ;-) ), is the thermocouple the small tubular unit w/ the other lead into the control unit and directly above the pilot flame?
Old 07-13-2003, 09:12 AM   #4
Contributing Member
Pahaska's Avatar
Correct. The thermocouple has to stay in the flame at all times to generate the small electrical potential that keeps the gas valve actuated. If the flame is pulled off, even momentarily, the valve will shut off.
Here in Texas. a lot of folks have problems with high winds pulling the flame away and the WH going off. My old Scamp did that sometimes until I did some bending to keep the flame playing on the thermocouple better.
John W. Irwin
WBCCI #9632
Old 07-13-2003, 09:15 AM   #5
Contributing Member
Pahaska's Avatar
Also ...
I should have mentioned that sometimes thermocouples do get weak and sometimes totally fail. Years of being in the flame and long periods of exposure to the elements will ultimately eat away the metal sheath. They only cost a few dollars to replace.
John W. Irwin
WBCCI #9632
Old 07-13-2003, 10:20 AM   #6
Marko69AS's Avatar
This sounds like good advise...thanks. Not only is the thermocouple farther away from the pilot flame than the recommended pilot flame height, the water heater is on the windy side of the trailer.
Old 07-13-2003, 04:50 PM   #7
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I went out a few weeks back with my newly installed atwood water heater.
I blew out 3 times in four days.
I called atwood and they acted like that was normal.
They have an optional pilot relight module that runs off a 9 volt battery so it needs no other wiring. It senses the flame and when it is not there it creates a spark to ignite it.
I assume you could also light it then w/o a match this way but I am not sure.
It's around $60. I was thinking of getting one.
-Tim
1960 International Ambassador 28'
2001 Silverado 2500HD CC 6.0L 4.10
Check out my book: Restoring a Dream
Check out my Airstream book for kids!: Airstream Adventures
theVAP - Airstream Podcast
Safari Tim is offline   Reply With Quote
Old 07-13-2003, 05:17 PM   #8
Gordon Watt's Avatar
Water Heater Pilot
I had to replace the control unit ($135.00) to get the pilot to work.
My heater is only 3 years old but is used all summer every day.
Gordon Watt is offline   Reply With Quote
Old 07-14-2003, 09:46 AM   #9
Marko69AS's Avatar
Talking Seems to have done the trick!
Thanks Pahaska!
Just a little bending and adjusting and wallah, I seem to have the issue fixed (at least all day yesterday and through a windy evening and a couple of cycles this morning)...at least greatly improved.
Thanks again,
Marko
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
pilot light on water heater kthomson Water Heaters, Filters & Pumps 2 12-30-2003 08:38 PM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
