Old 07-22-2011, 05:34 PM   #1
stream lady's Avatar
1975 Argosy 20
new iberia , Louisiana
Water Heater on 1977 overlander
We are thinking about replaceing our water heater on the 77 overlander, has anyone else replace theirs on a 77? If so how hard is it to take out?
Thanks for any help
stream lady is offline   Reply With Quote
Old 07-22-2011, 05:40 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Taking it out isn't hard, though you may have to work a bit to get any stuck-on Vulkem unattached from it. Unscrew all the screws, unhook the LP and water connections, and kick it out the side of the trailer.
Old 07-23-2011, 08:34 AM   #3
1975 Argosy 20
1977 overlander
Thanks that sounds good,so how hard putting the knew one back, I guess just the same just having patience
Old 07-23-2011, 11:03 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I was wondering if your water heater is leaking or just not working. I just rebuilt mine. I installed a new valve and pilot and thermo-couple assembly and it works like a champ. ITs not a difficult job at all. Total cost was about 100 bucks plus my labor. New heaters start somewhere around 350 and up depending on what you buy and from whom. GOOD LUCK with whatever you decide.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-23-2011, 04:21 PM   #5
1975 Argosy 20
We tried to like the pilot and it would not lite other then that we don"t know much about them.We are knew at the vintage and have a lot yet to learn.
Thanks Sarah & Howard
Old 07-23-2011, 04:42 PM   #6
Well Preserved
1993 21' Sovereign
The only real headache for you would be rerouting the LP line to go straight down, rather than toward the interior of the trailer, which is how newer trailers are routed. You would need to drill a LP line sized hole in the base of the water heater surround, and plug off the hole going back into the trailer. other than that, it should be a pretty basic swap. You may or may not have to do something with the water heater door, depending on how the original was installed.
Old 07-23-2011, 06:09 PM   #7
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
If your water heater is the original Bowen and is not leaking you may not have to replace it. I have the original in my 77 and have been told by more than one Airstream repair shop that the glass lined tank will never fail unless you screw the pressure relief or the gas valve assembly too tightly, which will crack the glass. Otherwise, just replace thermocouples and valve control assembly if needed. If your WH is in the rear, it will take more than 5 minutes of pressing the pilot knob before gas flow will light the pilot.
4RXLA is offline   Reply With Quote
Old 07-23-2011, 06:41 PM   #8
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
I find the easiest way to light the pilot in mine is to hold a torch on it till it goes. Trying it with a match or that silly flint lighter is next to useless, especially in any sort of breeze.............Phil.
pgr32e is offline   Reply With Quote
Old 07-24-2011, 10:39 AM   #9
1975 Argosy 20
I'm sure its the original {atwood ] Looks just like the one Inland has 6 Gal' pilot ignition,but I haven't seen where to order a valve,pilot and thormo-couple that looks like that one? Where did you get yours ?
Thanks Howard
Old 07-24-2011, 12:08 PM   #10
Well Preserved
1993 21' Sovereign
I think your '77 has a 10 gallon model, check before you order anything. It will say inside the door.
Old 07-24-2011, 12:35 PM   #11
1975 Argosy 20
I went look at the specifications on airstream inc. and says the 77 have a super 6 on all 77. the lable on the door was gone.
Old 07-24-2011, 09:51 PM   #12
Ottawa , ON
I think you will find that the thermocouple and pilot assembly are generic. Try your local RV store.
The WH's gas valve is another story: not generic, and not cheap!
Water heater cabinet cover to 1974 Overlander GeoStreamer Cabinets, Counter Tops & Furnishings 3 05-30-2011 12:35 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 07:27 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
