Old 10-18-2015, 06:16 AM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Water heater on 12v?
I'm assuming the WH runs on propane or shore power electric but not on batteries. Is that correct?
I ask because when I went to take my batteries out for the winter yesterday, I was cleaning out the trailer first and in the bathroom saw the electric WH switch in the on position. Since the unit is winterized and WH is empty, if it tried to heat an empty tank it would die pretty quick. But the red light wasn't on. So I'm assuming (and hoping) the electric only works on shore power.
Old 10-18-2015, 06:26 AM   #2
SteveH's Avatar
Common Sense , Texas
Yes, the electric function only works on shore power (120 VAC).
Regards,
Steve
Old 10-18-2015, 06:58 AM   #3
W , New England
Thanks. I can enjoy the winter now 😄
Old 10-18-2015, 07:02 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Leaving the electric heating switch on when not connected to shore power does seem to energize a circuit via the batteries. I say this because I notice a hum in the water heater that stops as soon as I turn off the switch. If nothing else it might just add to draining the batteries more quickly.
2012 Dodge Durango Hemi/AWD
Old 10-18-2015, 07:28 AM   #5
W , New England
Thankfully it could only have been for a few minutes. I know it was off when we left our last campground the prior weekend (I double checked it before leaving). So I'm guessing I bumped in to it when dewinterizing with the dealer.
Old 10-18-2015, 07:32 AM   #6
SteveH's Avatar
I would caution you to never turn the power switch on to the water heater when connected to shore power without water in the system, as it will burn out the heater element.
Regards,
Steve
Old 10-18-2015, 07:35 AM   #7
W , New England
That's exactly why I asked the question. The one things the dealer instilled in me was to NEVER EVER EVER let that happen! So when I saw the switch on and my batteries were still connected, I had a minor panic attack but figured - the red "failure" light would have to be on....
Very glad for the clarification.
Old 10-18-2015, 08:39 AM   #8
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Most water heaters use 12 v. power for control purposes, even when running on propane. You probably powered a circuit board, not the heater element,
Old 10-18-2015, 09:07 AM   #9
Mission , Texas
Yep ... 12vdc to the ignitor and gas brain.
The 110vac on our Atwood only goes to the heating element and its brain.
nrgtrakr is offline   Reply With Quote
Old 10-18-2015, 11:03 AM   #10
2016 30' Classic
Santa Rosa , California
Just to clarify...in normal operation of the water heater via the electric heating element, the red light will NOT be on. The red light only comes on when the propane gas switch is turned and indicates that the ignition spark is trying to light the gas. The light will only stay red if the propane ignition phase fails. The only visual indication that the electric and/or propane water tank heating options are turned on or not is the toggle position of the wall switches.
phann is offline   Reply With Quote
12v
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
