Old 08-17-2007, 04:28 PM   #1
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
Water heater off @ night?
Is there general consensus on if's it's best to turn off water heater at night or is it best to leave on to minimize LP consumption? Climate/region/season dependent?
ostream is offline   Reply With Quote
Old 08-17-2007, 04:32 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Not sure if you'll get consensus....
I usually leave mine on unless the noise of it firing up during the night bothers me. I installed an electric ignition model, so it's easier to turn off/on.
I don't know that the difference in fuel consumption would be real significant. ??
Dave
Fyrzowt is offline   Reply With Quote
Old 08-17-2007, 04:33 PM   #3
myoung's Avatar
Nipomo , California
Images: 24
We find that the water heater is so efficient and quick that we only turn it on a few minutes before we need it for washing body or dishes. The heater is well-insulated so it will hold the heat for quite a while, so we turn it off as soon as possible as well.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion" (coming soon)
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
Old 08-17-2007, 04:34 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Consensus? We don't need no -----ing consensus! You'll never get us to agree on anything as simple as that. After all some of us have LP to burn. Some will find the question luke-warm, while others are already in over their heads–not that I intended to throw cold water on your inquiry though
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-17-2007, 05:50 PM   #5
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
We have the gas/electric water heater. It is so efficient, plus it heats way to hot, that we can turn it on for a short time in the morning and have hot water all day. After each trip we always drain water in the heater and the water lines. Also blow the system with compressed air. This seems to keep the system clean and fresh.
fltlevel510 is offline   Reply With Quote
Old 08-17-2007, 06:06 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I turn mine off when not in use. In most cases after a full cycle and use, the water in the tank stays at the very least pretty warm, even 24 hours later......
Old 08-17-2007, 06:54 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We usually turn on the water heater a bit before we intend to use it...it doesn't take long to heat up the water, and it stays hot for quite a long while. I turn it off at night so we I don't hear have to listen to it fire up during the night, as it's fairly close to the bed area.
TB
Old 08-17-2007, 07:03 PM   #8
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I guess I haven't camped in cold enough weather, because I've never heard mine go on at night and it's right under the bed.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 08-17-2007, 07:04 PM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i turn mine on when i arrive and turn it off when i leave.
john
you call them ferrets, i call them weasels.
Old 08-17-2007, 07:16 PM   #10
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Yeah,
what John said.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 08-17-2007, 07:23 PM   #11
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I must be getting crotchety in my old age...it goes off at night now.Seems like the noise bothers me now (Didn't use to...)
I am the first one up in the a.m. and hit the "on" switch then (that room is my first stop in the morning anyway!) Water is still warm enough to wash up and only takes a few minutes to heat full temp.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 08-17-2007, 07:28 PM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Mine is turned on in the evening if I need to wash dishes and then turned off. The second thing I do when I wake up in the morning is fire the water heater up, go back to sleep for another 30 minutes to an hour then wake up to take a good shower. After the shower it is turned off again until needed. This is if I am in a campground and I decide not to use the community showers.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-18-2007, 12:52 AM   #13
ostream's Avatar
yep, consensus was pretty silly thing to ask for, never the less, I appreciate the responses and will be turning off my heater tonight. thanks!
Old 08-18-2007, 06:49 AM   #14
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
The top ten reasons to keep a water heater running 24/7...
10. You have a large family
9. You wash dishes 3+ times per day
8. You have unlimited access to refilling your propane tank
7. You like to take 3+ showers per day
6. Your spouse likes to take 3+ showers per day
5. You don't want to have to think about remembering to turn it on and off
4. ?
3. ?
2. ?
1. ?
OK, I can't think of 10 reasons...feel free to help with my list!
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 10:13 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
