Old 08-22-2007, 06:00 PM   #29
1971 21' Globetrotter
Melrose , Florida
My vote is to conserve lp
Skytrailer is offline   Reply With Quote
Old 08-22-2007, 06:38 PM   #30
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Originally Posted by InsideOut
We turn ours "on" when we arrive and "off" when we leave. Ours is vintage which means you have to go outside and take off the cover to light it with a flame....playing with fire is not something I want to do first thing in the morning before my shower.
Shari
Same here. Lighting the water heater in the rain on a windy morning, no thank you. I have never heard ours cycle at night even when it has been well below freezing. Then again I don't hear much of anything any more.
Richard
Old 08-22-2007, 06:55 PM   #31
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by Excella CM
Consensus? We don't need no -----ing consensus! You'll never get us to agree on anything as simple as that.
I have to disagree with that...
Old 08-22-2007, 11:07 PM   #32
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
On the other hand, re-read the variety of opinions. Might the proof be in the pudding?
Dave
Fyrzowt is offline   Reply With Quote
Old 08-23-2007, 03:11 AM   #33
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
No!
Originally Posted by ostream
Is there general consensus on if it's best to turn off water heater at night or is it best to leave on to minimize LP consumption? Climate/region/season dependent?
NO!
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 08-23-2007, 06:09 AM   #34
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
We turn it on 5 minutes before showering or doing dishes. Turn it off when done.
What about the draining issue? We usually have a week to 2 weeks between trips. We drain the water before storing the trailer, but I don't drain the hot water tank. Should I be doing so?
Drain or not to drain between short storage... thoughts?
campadk is offline   Reply With Quote
Old 08-23-2007, 06:29 AM   #35
Mrs_RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
Our water heater also has an electronic ignition. I flip the switch 10 to 15 minutes before I need hot water in the morning then turn it off when I'm done. It stays hot pretty much all day.
Now, if we had a water heater similar to the ones my parents had when camping and we needed to go outside to light the thing, no way would I turn it off until my camping stay was over.
The electronic ignition on our first camper (SOB) surely put a smile on my face.
We don't blow out the water heater, but I do run diluted bleach through it a couple times a year. Last year we got hold of some very sulfury water at a state park and now it seems like the hot water smells funny (sort of sulfur-ish) if we don't use a bit of bleach now and then. We were told by a fellow knowledgable airstreamer that older water heaters can get a good layer of deposits from hard water (boy, we do have that) and the deposit layer will absorb and latch onto odors. I don't know if that is the only reason but the infrequent bleaching does seem to help.
Mrs_RedSHED is offline   Reply With Quote
Old 08-23-2007, 08:12 AM   #36
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yep, me too.
Originally Posted by Pick
When I lived in my Airstream for 4 months, I kept it on all the time. It really doesn't use that much propane, plus it keeps the spiders from taking up residence in the burn tube, also keeps moisture out, which keeps things from rusting.
I live in mine too, and I also leave it on. I also use my stove daily for at least one meal.
I just refilled my two 30lb propane tanks on Monday... the last time I put propane in was in March, so that should be a testimony to how little propane you use with these two appliances.
In winter I was surprised and shocked at how fast the furnace burned through propane! It also blasts two minutes of cold air followed by hot, hot air, then stops, waits for the temperature to drop and starts all over again.
RV furnaces have apparently "always been that way" and no one is working on a better system for mass production. I do think there was a thread about someone who adapted a water heater, a pump, a thermostat and some flexible tubing into a hot water radiator system for an RV... I think using computer fans to gently move the heat throughout the interior area, with tubing in the belly to keep the tanks from freezing. Actually I can't think why "in the floor" (under the plywood) radiant heat wouldn't work for an Airstream. I know it would use a fraction of the heat a furnace does... Brain working... will a second water heater fit in the space where the furnace is? Venting to outside? Taking off the belly pan and insulation and... (OK that sounds like work and I'm over it now ... but who do I know who has talent and likes money? Hmmm... )
Paula
Foiled Again is online now   Reply With Quote
Old 08-23-2007, 08:31 AM   #37
dmreilly10000's Avatar
1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
It depends. When I had my 1963 Overlander with a pilot light, I left it on all night. Too much trouble to have to get dressed and go outside early in the morning and light it.
When I had my 1991 Excella with an electronic ignition and an on/off switch in the bathroom, I turned it off each night.
This might sound lazy, but most use of my trailer use has been at my deer camp and lighting the water heater meant going outside in sub-freezing temps, in the dark between 4:30 to 5:00 AM in the morning.
The 1953 pictured in my avitar came with an electric water heater. (still being restored and not useable)
Electronic ignition is a wonderful thing.
dmreilly10000 is offline   Reply With Quote
Old 08-23-2007, 03:04 PM   #38
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
This may be a stupid question, but how does one put bleach in the water heater? pj
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 08-23-2007, 05:48 PM   #39
2014 16' Sport
Columbus , Indiana
Not a stupid question, just a description by me that was probably not as specific as was necessary.
I don't put it directly in the water heater tank. I add bleach (and water) to the water tank the same as if I were going to sanitize the tank in the spring. Then run the hot water spigot(s) until I can smell the bleach a bit. Let sit overnight or a day or two. Drain and rinse well.
Old 09-10-2007, 04:55 PM   #40
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Hot Enough For Ya??
Originally Posted by john hd
3 it uses so little propane it is not worth worring about. remember you are on vacation!
john
YEAH.....What he said!!!!!
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-10-2007, 05:11 PM   #41
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Our water heater gets turned on/off inadvertantly while camping. The switch is in the bathroom, and, looks just like the light switch. I do flush out the hot water tank with a special hose nossle that camping world sells for that purpose. I also put an anode bar on the drain valve to prevent mineral build-up.
Tom
henw is offline   Reply With Quote
Old 09-10-2007, 06:36 PM   #42
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Cold Sweat
Consensus? We don't need no -----ing consensus! You'll never get us to agree on anything as simple as that. After all some of us have LP to burn. Some will find the question luke-warm, while others are already in over their headsĖnot that I intended to throw cold water on your inquiry though
I'm watching what he does, and doing just the opposite!
Just do this once ...and you will know the answer.
"I usually remember to turn ours on just as the cold water is spraying on my wife in the shower and I hear this awful squeal coming from the bathroom area. I then rush over and hit the switch - so that I can honestly reply that the hot water heater is on when asked in a very seductive tone "is the darn hot water on????". With everything else in need of repairs it's not to hard for me just to blame it on the trailer.... "
klattu is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 10:13 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
