Old 10-26-2012, 09:10 PM   #1
Blockstream's Avatar
Water Heater Not Working!
We have a 2006 25ft Safari FB. Just finished unhooking and I went to start the hot water heater by flipping the switch in the bathroom and the light doesn't go on, nor will the hot water heater start. I know the propane tanks is filled because the stove went on. I've never had this problem in the past. Any suggestions?
Blockstream is offline   Reply With Quote
Old 10-26-2012, 09:47 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Check all the electrical connections. Without a light (assuming the bulb is good), you don't have continuity through the system.
SeeMore is offline   Reply With Quote
Old 10-26-2012, 10:16 PM   #3
Thanks for the tip.... I checked the fuses, but nothing is labeled Hot Water Heater. Where would I check for continuity?
Old 10-27-2012, 06:52 AM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Open water heater compartment and there are a bunch of electrical connections. Pull each one off (one at a time so you don't get them mixed up) and clean the contacts and push them back on. Over time corrosion builds up and sometimes just moving them on and off does the trick. This happened to us earlier this year and that's all I had to do. You can clean them with WD-40 or some light sandpaper.
If that does work, well, it could be the ignitor has gone bad or the circuit board has.
Gene
Old 10-27-2012, 07:13 AM   #5
That worked like a charm! I cleaned the connections, plugged them back in, flipped the switch, and the pilot light started right up.
Many thanks for the help!!!!
Old 10-27-2012, 10:08 AM   #6
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I love it when the simple no cost solution works!
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 10-27-2012, 10:20 AM   #7
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Brilliant. I'm remembering that one.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 10-27-2012, 11:16 AM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Huh? I didn't know that Airstream used Lucas wiring! (If you need it, I can supply the link to the official Lucas smoke replacement kit.)
Lynn
Gene
WBCCI 21043
Water Heater Drain wlanford Water Heaters, Filters & Pumps 14 01-25-2012 08:12 PM
'73 Original water heater - keep or chuck? Jamiep Water Heaters, Filters & Pumps 2 12-16-2011 01:48 PM
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Tankless Water Heater lucymcdog Water Heaters, Filters & Pumps 4 07-04-2011 05:00 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
