Old 12-21-2014, 08:13 PM   #1
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Water heater not working.
2007 Airstream international wit Atwood 6 gal water heater.It has been working great and then it sat for 30 days in storage.Now won't work on gas or electric.Checked circuit board fuse and spade connections.Light comes on and stays on with gas.plugged into shore power and everything else functions on gas or electric.Any ideas?Circuit board?
Old 12-21-2014, 08:24 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
My guess is the board.
A good RV shop should have a test jig, to be sure.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 12-21-2014, 08:36 PM   #3
Moflash's Avatar
I was leaning towards the board also.
Old 12-21-2014, 10:12 PM   #4
1974 Argosy 20
Kooskia , Idaho
The gas side of the water heater has a circuit board for ignition and safety issues. However that should not affect, in any way, the 120 volt side which does not go through the circuit board at all. They are completely independent, and in fact can both run at the same time for faster water heating. I can see one or the other going out, but not both at the same time.
So, although I believe what you are saying, it is hard to imagine anything which would cause both parts to go out at the same time other than really bad luck.
Wish I had a magic solution for you but you are going to have to solve first one of the heat source problems, then go on to the second one. I would attack the 120 volt side first, it is the most straightforward of the two. Be sure that there is 120 volts at the water heater, then check the continuity of the thermostatic switch and the heating element itself.
Old 12-21-2014, 10:18 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I agree - but it is a 2007. About time for the electrical element to wear out. It's possible that the electric had failed to work for a while, and the owner didn't notice if he was running both at the same time. A couple of weeks later tha board goes bad too? Replacing the element is pretty inexpensive and if that doesn't fix the electrical side... well you have a spare element you'll need sooner or later.
Paula
Old 12-22-2014, 10:11 AM   #6
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
The electric side of the water heater can be compromised if the water tank runs dry while a hot tap is open. If air gets into the heater tank and the element isn't fully submerged, it will burn out in minutes. Was the tank drained when the trailer went into storage?
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 12-22-2014, 11:37 AM   #7
2006 19' Safari SE
Hayes , Virginia
Mine was doing exactly same thing. I changed what I could and still didn't work. Finally decided to read the book. Once I adjusted the igniter, she works every time. I was first adjusting by putting the igniter tip as close "IN" as possible. Wrong. I loosened the igniter and backed it off a little at a time and bingo, I hit the sweet spot and she works every time (I was adjusting the igniter in as far as I could get it, rather than the opposite way). The instructions say 1/4" or 1/8" gap or something like that. Sorry, I cannot explain it better....but, it works)
mocus is offline   Reply With Quote
Old 12-22-2014, 12:16 PM   #8
Moflash's Avatar
Tank was drained when stored but refilled an bled before hooked to shore power. I have searched high and low for the electric element location,does not appear to be on the outside and do not see it on back side????Hmmm
Old 12-22-2014, 02:06 PM   #9
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I don't have any specific solution to suggest but wanted to point out that when the light by the gas/electric switches is on, the heater unit is in "fault." Oddly enough, when the light is OFF, the hot water unit is working properly, when the light is ON, it's not. Go figure?
Bob Martel
WBCCI# 5766
Old 12-22-2014, 02:16 PM   #10
WaLee's Avatar
Nevada City , California
My gas only unit failed to light after de winterizing this weekend for a trip to Santa Cruz. The trailer was set to run and plugged into shore power before i left while packing snd cooling the fridge. De winterized filled the tank and took off. Heater wouldn't fire all weekend. Wasn't a big deal as the campground had baths and hookups.
Called the local RV shop here this morning. Service manager suggested a re-set. Disconnect the batteries, then connect ( store/run). The reset worked. Hot water again. Now to re-winterize!
WaLee is offline   Reply With Quote
Old 12-22-2014, 03:31 PM   #11
Moflash's Avatar
Yea,go figure.
Old 12-22-2014, 03:33 PM   #12
Moflash's Avatar
Now that's a new one.Reboot with the store button.
Old 12-22-2014, 03:36 PM   #13
Moflash's Avatar
Searched high and low for electric heating element but to no avail.Hard to replace when you can't find it!
Old 12-22-2014, 04:35 PM   #14
jdalrymple's Avatar
Jay , Oklahoma
Dumb question here, but are you sure there is one?
A lot of trailers have propane only....
Is there a 120 volt wall switch or breaker for the water heater?
Or just the 12 volt/indicator light?
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Water heater not working nilesrob General Repair Forum 16 11-21-2012 08:37 AM
Water heater is not working Densin E. LP Gas, Piping, Tanks & Regulators 5 08-26-2012 08:53 AM
Trailer Atwood Water Heater not working? silverback Water Heaters, Filters & Pumps 2 06-01-2010 08:52 AM
New Water Heater Not Working Properly BobbyWhitit Water Heaters, Filters & Pumps 8 04-18-2010 01:10 PM
Water heater bypass not working Rob30044 Winterizing, Storage, Carports & Covers 7 12-05-2005 06:33 PM
