11-21-2013, 08:49 AM
1996 28' Excella
Cotati
, 94931
Water heater not staying on
1996, 28' Excella
I live in my trailer and shut of the hot water heater for a few days while I was away. There is a fill LP tank, and the gas is getting to the hot water heater. When I turned it back on, the ignition lights the heater, the fire comes on, then after a few seconds it goes off, and the light is red (like it is when it is out of gas, except I know there is gas). I don't know how to fix these things. Any suggestions.
Thanks.
11-21-2013, 08:57 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
First a dumb question… Are you sure there's water in the heater? You mentioned propane and spark, but not water.
Then some speculation… Could be a faulty thermostat. I had a faulty thermostat on mine, that wouldn't shut off the flame until the water was almost boiling, leading to a red fault light from overheating. But it's possible for it to fail the other way, shutting off the flame while the water is still cold.
I didn't replace my own thermostat, so I can't tell you how it was done. In my case, it was a warranty issue, that cropped up on my very first camping trip in my Airstream, so I wasn't about to let Airstream off the hook by fixing it myself.
11-21-2013, 08:59 AM
2016 28' Pendleton
Scottsdale
Hi from AZ. . . in most water heater applications, a thermocouple is used to allow gas valve to open if it's hot. Sounds like your thermo is bad. Pretty easy replacement, make sure the pointy end will be IN the flame...... good luck, Regards, Craig
WBCCI 2851,4CU
11-21-2013, 09:51 AM
1995 30' Excella
Bowie
, Maryland
Thermostats are super easy to replace - they just twist and pop out. They (and the ECO) are cheap enough that you might throw new ones on just to test, but I'm not convinced that's what's wrong with yours. A bad thermostat usually means it would still "work" - it wouldn't turn on the red light. In your case, obviously the electronics have decided something is amiss, and it's turning on the red light.
I think I'd go out and watch it (with the door open, but stand back in case something weird is going on) to see what it's doing while someone turns on the switch inside.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
11-21-2013, 10:14 AM
Austin
We replaced our thermostat and several other things to no avail. Started doing something similar after we had it polished and had everything turned off for a month. Finally we replaced the water heater. Surprise, surprise the new one did the same things. So finally we blew out the gas lines. It was getting enough gas to turn on and heat somewhat sometime but not enough to work properly because of crud buildup while it sat. It works perfect now.
11-21-2013, 10:37 AM
1996 28' Excella
Cotati
, 94931
Gosh, thank you all so much for your help and so quick!! I think I'll start and replace the thermostat. I'll let ya'll know how it goes!
11-21-2013, 10:57 AM
2016 28' Pendleton
Scottsdale
Hi from AZ. . . I was talking about thermocouple, not thermostat. F Y I , regards, Craig
WBCCI 2851,4CU
11-21-2013, 06:52 PM
1987 25' Sovereign
Fort Collins
yve79: never heard of such a thing as crud in gas lines, but that might explain the issue we've had. Any advice on blowing out the lines --just a good blast of compressed air, or (?)
Alumacoot
“We are confronted with insurmountable opportunities.”
11-21-2013, 07:10 PM
Briarcliff
" Hot water heater"?
1966 T-27 Avion (Sold & missed)
2022 Escape 19
From All Over
"Crud" covers a lot of territory. The compartment isn't sealed, so there may be road grime, blown dust, spiderwebs, the remains of a wasp nest that never quite got built, you name it.
