Old 02-08-2004, 11:32 AM   #1
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
"Water Heater" not lighting
I just installed my new 10 gal Atwood 110v/LP "water heater." First try, no water leaks at any of the connections!
Tested gas lines for leaks. They were fine too.
Problem... I follow the simple instructions for lighting the pilot, but don't even get the hint of a "poof" of ignition. Just to make sure I was getting gas, I eased off the fitting at the regulator, and with a testing solution got bubbles. I tightened it back up and tried again. Still nothing.
Atwood doesn't have a trouble shooting section in their manual, and they only answer the phone during the week.
Just to be sure I was gassed up, I ran the burners on the stove, as well as the propane heater and gas light. So I know I have gas flow. I shut those appliances off when attempting to light the pilot.
Any suggestions?
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 02-08-2004, 12:11 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Sneakinup,
Try this if you can. Set the temp lever in the middle of the range, hold the knob in the pilot position and using a butane ignitor keep the flame under the threocouple probe for 20 seconds. While keeping the flame on the themocouple turn the knob to the on position. This will open the main gas valve and the main burner should light. If not then you may have a gas valve problem.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-08-2004, 01:49 PM   #3
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
We have HOT WATER!
Thanks Brett. Worked like a charm. Nice and toasty hot water on a cold Florida day!
Now I have to do the electric hookup and I am all set.
