Old 09-02-2013, 02:19 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Water heater not igniting - could it be the switch?
My Atwood electric ignition 6-gallon heater is being sporadic. The switch shows no light on (which I assume means no power to the heater), but I checked the connections with a 12-volt meter and there is power to it. I thought maybe it was the fuse, so I removed it and still no ignition. What else should I check?
adwriter73 is offline   Reply With Quote
Old 09-02-2013, 02:24 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Is the igniter clicking?
It may be the control board.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-02-2013, 04:07 PM   #3
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Not clicking. But then it came on. I turned it on and off several times, and it worked. Now it's not working anymore. I took everything apart and cleaned the connections. Still nothing.
Old 09-02-2013, 04:27 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Light illumination occurs when there is no ignition. When first turned on there will be a brief lighting of lamp. When the system senses combustion the light goes out.
If the heater tries to redirect later to warm water again the cycle repeats.
I had a corroded flame sensor. Cleaning helped but only a little while. Replaced and working fine. If in a pinch you can scrape it down with a fingernail file.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-02-2013, 04:27 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also, are you sure all air is out of your LP system?
Channing
WBCCI# 30676
