Old 12-20-2003, 07:28 PM   #15
WayWard Wind's Avatar
2004 25' Safari
Susan--another idea, especially when it's dark, would be for one to watch the water heater pilot & burner on the outside , while another one could flip the switch. You should observe a sparking action as it trys to light the pilot. If you can see the sparks, but not lighting the pilot, then you may need to check if there is gas coming thru to the pilot. At this time unless you feel comfortable, it's time for a qualified service person to check it out. When it's time for vacation, that's when we all want to be in hot water. Hope all goes well & you end up in hot water.
Season's Greetings,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 12-20-2003, 10:59 PM   #16
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
I bet its the circuit board, like John said. It went out on me on my summer trip. The service tech said they go bad ever so often and that I should carry an extra one. It is easy to replace once you know where it is but the board is expensive.
Big Dee is offline   Reply With Quote
Old 12-21-2003, 07:48 AM   #17
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally posted by John
Susan,
I had to replace my WH pc board because I had the same situation; flip on switch and get a steady red light with no spark.
I believe there are 2 types and their about $110 ea.
Easy to install. Most RV center carry them.
Good luck-John
Before replacing that board unplug it and inspect it for any sort of corrosion. Especially look at the plug on it.
If you find any corrosion a small brush and rubbing alcohol and clean it off and see if it works.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 12-21-2003, 08:07 AM   #18
Gordon Watt's Avatar
I had to replace the regulator on my 4 year old water heater this past summer. However it is a manual heater.
Gordon Watt is offline   Reply With Quote
Old 12-21-2003, 09:02 AM   #19
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
trouble shooting guide
susan,
here is a link for atwood's trouble shooting guide.
it has a phone number and a e mail address for you to speak directly to them.
http://www.atwoodmobile.com/Service/...e/electric.cfm
john
you call them ferrets, i call them weasels.
Old 12-21-2003, 09:38 AM   #20
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Originally posted by susanborck
john...the disconnect didn't work...any where to go to next? is it time for service?
can you tell me where the eco switch and thermostat are located? the owner's manual refers to these two parts in troubleshooting but we can't locate so we can continue.
susan,
as requested, best photo i have.
john
Old 12-22-2003, 07:45 AM   #21
susanborck's Avatar
hotwater heater
thanks to all for the help. going to a rv dealer and try a new board.
thanks susan
thanks, susan
susanborck is offline   Reply With Quote
Old 12-22-2003, 09:01 PM   #22
susanborck's Avatar
John! Wow! you are the best! Thanks to you and the other guys, we visited the water heater mfg'rs website, located a dealer, called them, got the info together we needed to identify the model/year, etc. for the right part, brought it home, installed it and....ta da...I HAVE HOT WATER! This will be the warmest, cleanest christmas ever!
Our thanks and best wishes to all of you and your families for the merriest of Christmases and a healthy, happy and prosperous new year. Just when you often feel you live in a world where people don't really care about much, you find a great tool like this forum where people are so at the ready to help. And where the "return" is to participate. I am so happy to have such a wonderful introduction into the airstream community. I am delighted to have made this new acquaintance.
Thank you.
thanks, susan
Old 12-22-2003, 09:10 PM   #23
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Yipppeee!!!!
Safe travels & warm showers!
H A P P Y H O L I D A Y S !
Shari
Old 12-22-2003, 10:31 PM   #24
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Thumbs up
glad to hear you have hot water!
have a safe trip! and happy holidays!
john
