Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 03-13-2013, 08:38 AM   #1
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Water heater lime buildup
This maybe of some help to some folks. I just bought a 2001 AS 30' Excella, I drained the water heater (6 gallon Atwood). There was a lot of lime and sediment as the last quart or so of water drained out.
I removed the pressure relief valve, and made an adapter to be able to run a regular hose into the tank through the 1/2" relief valve hole. I ran the hose for about 3 minutes, and wasn't satisfied with what did not come out.
I called Atwood tech service, the rep told me to drain the tank, replace the drain plug and pour 4 gallons of white vinegar into the tank and let it sit for a day or so, then drain it, and rinse it by filling and draining a couple of times.
Amazing results! The acetic acid in the vinegar dissolves the lime and other crud, and really cleaned up the tank.
I knew this before, but the rep also emphasized that because Atwood uses an aluminum tank, do not use a magnesium anode, or you will get the rotten egg smell. Also to be sure an use a nylon 1/2" pipe plug, not brass.
Maybe his will help other folks.
Larry
Larry C is offline   Reply With Quote
Old 03-13-2013, 08:55 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Good report, thanks Larry.
Much of this may be avoided by using a portable RV water softener at your water inlet hose. Watch for frequent sale price at Camping World or other sources.
I wonder why no brass plug (although I stick with the nylon)? They use a brass pressure relief valve in the water heater.
doug k
Old 03-13-2013, 09:50 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
The only contact from the PR valve is rubber to aluminium Doug. If the rubber did not seal, the PR valve would leak.
Once the tank is drained, an air hose with and nozzle extension works good to lift the scale on the bottom of the tank.
Dave
doug k
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-13-2013, 11:02 AM   #4
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I have been using teflon tape on my replaced (couldn't find plastic) brass plug. Haven't had any thread galling after 5+ years
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 03-14-2013, 08:03 AM   #5
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I don't quite understand that either, as brass is a fairly inert metal. Like you though, it doesn't really matter, as I use a nylon plug also...
Old 03-14-2013, 08:07 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Those small water softeners are great, and they do a good job...if I can rearrange all my "stuff", I'm going to buy one....we used to live in northern Indiana, and had so much lime and iron in our water, we finally set up two water softeners in series, for the cooking and wash water, and an RO system for drinking water. But that's a bit much for the AS.
Larry
doug k
Old 04-03-2013, 04:53 PM   #7
FLMarine's Avatar
2009 27' FB International
_ , North Carolina
I double the vinegar in the hot water tank fix. I full time in my 2009 27 FB and after two years of full timing I had some calcium build up in my kitchen sink hot water lines that caused the hot water to come out as a trickle. I took all the water lines off and the hot water line had some build up that I cleaned up as best I could. I took the hot water drain plug off and filled the tank with 3 gallons of vinegar using a 1/2" adapter attached to a funnel and tubing I got from lowes.
Once I filled up the tank I turned the water back on and let it heat up and then turned on the hot water in the kitchen until I smelled the vinegar come through. Three hours later I let the hot water on for a bit to flush it out. The hot water comes out great now. The fix worked like a charm.
FLMarine is offline   Reply With Quote
Old 04-03-2013, 05:02 PM   #8
5T5
2004 28' Classic
2006 22' International CCD
Saskatoon , Saskatchewan
I use a brass plug because the plastic ones get brittle with age and tend to break.
Kim
5T5 is offline   Reply With Quote
