Old 07-05-2010, 03:00 PM   #1
T Reno's Avatar
1991 29' Excella
Colorado , Colorado
Water Heater leaking....
91 Excella 29' is my unit. Purchased in December with written verification that unit was properly winterized. Now in July ready for first trip and while filling water tank it is leaking out from behind the "pressure valve" aka pop off valve on the outside of the water heater access panel. Also water inside around the stool but not sure where its all coming from. My question is this an easy fix? Will I need to replace the water heater? Does the water heater just come out by removing all the sheet metal screws etc from the outside? Sounds like they forgot to drain and or winterize the water heater. Will this be expensive? please help.
T Reno is offline   Reply With Quote
1970 Sov Water heater leaking - tank replacement? chasrahm Water Heaters, Filters & Pumps 5 10-28-2009 01:34 PM
Leaking hi pressure water heater hose Astrodokk Water Heaters, Filters & Pumps 8 06-05-2005 10:13 PM
Water Heater leaking jaiman Water Heaters, Filters & Pumps 2 07-31-2004 04:44 PM
Water Heater T&P 99 Bambi Leaking, need advice JimBrownUT Water Heaters, Filters & Pumps 3 01-14-2004 02:46 AM
Water Heater Leaking Outside overlander76 Water Heaters, Filters & Pumps 8 11-02-2003 03:11 PM
