Old 05-07-2016, 06:00 PM   #1
btowntincan's Avatar
Mercer Island , Washington
water heater issue
hi there,
I think I have an issue with my water heater. Was working fine on our last camping trip, but stopped after a day. I seem to have blown my thermal cutoff fuse (I overrode it and the unit works). In checking the function, I do have flames in the right place, but from time to time I noticed it flames in the front area (circled in yellow in the picture). That doesn't seem right. Any advice on how to fix it?
I don't notice any obvious blockages (critters and such).
Name:	furnace issue.jpg
btowntincan is offline   Reply With Quote
Old 05-07-2016, 07:44 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
It appears that the air shutter is way too open. Try loosening the little screw and closing the gap a little. If I recall correctly my manual specs. 25" or less opening of the shutter.
Old 05-08-2016, 03:05 PM   #3
aha. I'll give that a shot. Thanks for the advice!
Old 05-08-2016, 04:58 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You should also check your propane pressure, or have it checked. I made a manometer (Google is your friend) and found that my pressure was WAY low and dropped even further when the furnace came on.
In order to get a good flame, I had to open the air shutter too far. Low propane pressure could cause the flame to recede to the shutter.
You should have 11" water column (about 1.5 psi) at the heater with two other appliances running. I tried to adjust my regulator (2002 vintage) and it went from WAY low to WAY high. I replaced the regulator.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 05-09-2016, 11:00 AM   #5
I may try that as well.
I ended up disassembling the unit and found a tiny (very dead) spider in the tube that I couldn't see when it was installed. Seems to work fine now.
Thanks for the advice.
Old 05-09-2016, 11:20 AM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep, that would have been my first advice if I had gotten to this question a little earlier. Very typical of spiders and their webs in the tube. It's surprising how little debris in that tube will interrupt the proper flow of gas and air. It looks clean but once you disassemble the tube you will see the problem.
Jack
Jack Canavera
STL Mo.
AIR #56
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Water Heater Issue BronYAur Water Heaters, Filters & Pumps 3 02-03-2014 09:50 AM
2004 19' Bambi Safari Water Heater Issue TGadaire Water Heaters, Filters & Pumps 2 08-27-2012 07:46 AM
Bowen G6A2 water heater issue, pilot cuts off batt Water Heaters, Filters & Pumps 0 07-25-2012 07:12 AM
Water Heater Switch Issue on 2009 Flying Cloud! GAS_Wyo Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-16-2010 12:51 PM
