Old 06-30-2007, 12:25 PM   #1
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Water heater insulation
The insulation on my 10 year old Atwood water heater is pretty much gone. The cardboard and the fiberglass is ripped and torn beyond repair. I want to replace it but am wondering if there is a better way than to just wrap it in fiberglass insulation again. Any ideas?
Thanks.
Tom
1978 Ambassador
tlavergne is offline   Reply With Quote
Old 06-30-2007, 01:58 PM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
maybe try the foil-faced bubble stuff, called "reflectix" I believe. Seems to be the modern insulation of choice.
tphan is offline   Reply With Quote
Old 06-30-2007, 02:49 PM   #3
2002 19' Bambi
Lafayette , California
Considering that the bubble stuff can melt, you might want to check if it will stand up to the temperature of the water heater if you use it. Our water heater is encased in styrofoam which can also melt, so perhaps the bubble stuff is okay.
Tim A. is offline   Reply With Quote
Old 06-30-2007, 06:22 PM   #4
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I thought of the bubble stuff that is foil faced but, like you folks, wondered about the melting factor. It is also fairly thin and would probably want to layer it. Perhaps fiberglass is the best. I could buy a home water heater jacket, cut it to fit and duct tape it on. Does anyone know how hot they get? 130 or 140 degrees maybe?
Thanks for the responses.
Tom
Inside hot water heater cover davidz71 Water Heaters, Filters & Pumps 12 03-24-2008 08:11 PM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 10:13 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
