Old 01-22-2013, 08:18 PM   #1
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
water heater installation video
I have posted a video on you tube on the installation of a G6a-8E hot water heater in my Safari. The installation took about 3 hours from start to finishing the clean up.
The steps to be careful of are:
1. Turn off the water and Propane.
2. Depressurize the tank.
3. Drain the tank.
4. Put a towel under the water lines when cutting the water lines loose.
5. Careful with that gas line..do not crimp it when loosening or tightening.
6. Soap test the gas fitting when it is reconnected.
7. Use plenty of plumbers tape... it is cheap insurance.
8. Have someone else look at the installation before you fill the tank.
9. Go back in an hour and double check everything one more time.
Here is the link. Hot Water Heater Installation.mp4 - YouTube
Living life on the Road
deauxrite is offline   Reply With Quote
Old 02-14-2013, 09:12 PM   #2
mtbguy's Avatar
Dunwoody , Georgia
Is there any way you can send it to me? I tried the youtube link and it didn't work. I am about to do this in next few days, thanks!
Rick
mtbguy is offline   Reply With Quote
Old 02-15-2013, 01:06 AM   #3
Fishbowl's Avatar
1970 25' Caravanner
1970 25' Caravanner
Sechelt , British Columbia
Images: 8
I can't bring up the link on YouTube either and wonder if it might be a Mac related twist. I would like to have seen your video. Good procedure tips which I've copied and hung on my hot water tank for the dreaded day I should have a check list handy !
Fishbowl is offline   Reply With Quote
Old 05-15-2013, 06:08 PM   #4
2006 19' Safari SE
Hayes , Virginia
I tried to take a look also and had no luck clicking on your link. Thanks for trying anyway...
mocus is offline   Reply With Quote
Old 05-15-2013, 06:39 PM   #5
Ottawa , ON
I would add that IF you are replacing the WH in an older trailer, be prepared to have to move the entry points for the LP gas and electricity. No, I don't know why the WH manufacturer did that.
Guess how I know. :/
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Video: New Video from our 2010 summer trip to Austria (Alps) and South Germany aheun Global 'streaming 9 09-28-2010 03:54 PM
Water heater bypass installation Craig Water Heaters, Filters & Pumps 4 04-05-2003 04:13 PM
