Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-15-2008, 07:59 AM   #1
cameront120's Avatar
Profile:  1972 25' Tradewind
Water Heater Install Help?
I just received my new Atwood GC6AA-10E, combination gas/electric with electronic ignition. Does anyone have the patience to look at the photos of my electrical panel and wiring and describe how I hook up the wiring of the new heater?
Here is my electrical box:
Here it is showing 12v (2 wires) going to the bunk light in the upper right:
Here is the information on the inside cover of the existing electrical box shown in the first two photos:
Here is the back of the Atwood showing the 12v wires (blue, white orange and green) at the top. The 110v wires (green, black & white) are coming out of the black box at bottom. What isn't shown is the two switch unit that attaches to the wall. I've attached a PDF of the Install Manual and the last two pages show the switch as well as the wiring diagrams, etc.
This stcker is on the back of the heater:
Can anyone help, or am I better off hiring an electrician?
Cheers!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 05-15-2008, 09:33 AM   #2
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile Hi
If you have any knowledge of electricity it would be simple but according to you you have no idea. My recomendation is to hire an electrician. The question schould be how much current will your heater draw and do you have to upgrade the panel to a higher amparage brakers.
Regards from Russell in sunny and cool Tucson Az.
RUSSELL is offline   Reply With Quote
Old 05-15-2008, 09:41 AM   #3
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
If it was me doing this, I would upgrade to a more modern box with a couple more spaces for extra breakers and put in a dedicated circut for the water heater. Any good electrican should be able to easily do this if you do not feel comfortable installing a new box. Just make sure that you do not put in a main breaker that has an amp rating higher then the power cord is rated for.
Old 05-15-2008, 09:43 AM   #4
I'm willing to learn, sadly I just don't have the knowledge to tackle it.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 05-15-2008, 11:47 AM   #5
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
The question is first: How much power is the heater going to use? How many amps, (or how many watts/110). Heating appliances typically use a lot of power, so you may exceed the 20 amp supply (2000 Watt) from either breaker. As was suggested, you may need a box with one more breaker of sufficient size.
As was also said you will need to make sure the power cord to the trailer can handle the load when everything is running. You can add an extra box, or a bigger box. Have someone knowledgeable go over the set up with you.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-15-2008, 01:01 PM   #6
Okay, sounds like I need to hire someone. I know plumbers, engineers, roofers, but no electricians. Time to go make some phone calls.
Thanks for the input, all!
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 05-15-2008, 02:34 PM   #7
musketeer's Avatar
Profile:  1989 25' Excella
Kimball , Minnesota
Just finished mine & can help
I just finished wiring my identical w/h this morning. There are a couple of options, but you are going to need to install a new dedicated 15 amp circuit. Which means you will need to replace the existing electrical box or install an additional box for the new breaker. I sent a PM.
musketeer is offline   Reply With Quote
Pingbacks are On
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 32 03-24-2008 06:55 PM
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
need to install a water heater...choices? pixie Water Heaters, Filters & Pumps 6 03-20-2003 06:24 PM
SEO by vBSEO 3.1.0
