Old 11-30-2013, 08:35 PM   #1
groovzilla's Avatar
1966 20' Globetrotter
Seattle , Washington
Water heater install
one of the previous owners did a hack job where the old water heater was located and just covered the hole. i had to custom fit and flash the atwood electric/lp gas 6 gallon water heater today.
didn't turn out too bad
Name:	airstream water heater cover.jpg
ID:	201001   Click image for larger version
Name:	water heater final.jpg
groovzilla is offline   Reply With Quote
Old 11-30-2013, 08:53 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
So which is the before and after?
SeeMore is offline   Reply With Quote
Old 11-30-2013, 10:18 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Harsh!
I'm guessing the "before" is the one with duct tape and a wavy piece of sheet metal, and the "after" is the one with the standard Atwood door and no duct tape.
— David
Old 12-01-2013, 12:06 AM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Retraction
Oooh, my bad. I couldn't see much difference, if any, other than the appearance of a grill on my smartphone; magnified on a pad my response looks cruel.
Old 12-01-2013, 01:08 AM   #5
groovzilla's Avatar
i thought it was damn funny
the before photo has no large curved window and a larger than a walmart shopper hole in it's side covered with flashing and duct tape.
the after has a new curved glass window installed and a water heater/flashing filling the hole
i need to get a section of skin for the lower flashing and also a piece of original blue trim to fill the gap.
Old 02-15-2014, 09:50 AM   #6
1975 25' Tradewind
Aunsin , Texas
I'm installing an Atwood as well. What is the best sealant to use for this?
Bwilson11 is offline   Reply With Quote
Old 02-15-2014, 10:27 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I used the Parabond number that replaces Vulcum and it worked fine. Messy though,
Old 02-15-2014, 11:18 PM   #8
groovzilla's Avatar
its always been suggested to use aluminum color sikaflex for sealing roof vents and anything else needing sealing.
Old 02-20-2014, 12:33 PM   #9
1967 22' Safari
Elkton , Maryland
Looks good. I have to replace the HWH on mine too. I'll probably be getting the same kind as you, although maybe the 10 gallon. Ours still has the original door that is vented and is flush with the rest of the trailer, so hopefully we won't need to make any door modifications.
NJ Amanda is offline   Reply With Quote
Old 02-21-2014, 04:25 AM   #10
1975 25' Tradewind
Aunsin , Texas
Thanks for the replies! Picket up some puttytape and some vulkem (equivelant) on vintage trailers.com
Old 02-21-2014, 08:04 AM   #11
groovzilla's Avatar
they sell grey sikaflex at home depot for $7 a tube
Old 02-24-2014, 07:43 PM   #12
ole81's Avatar
1981 31' Excella II
Richmond , Texas
more details on the installlation, please....
It looks like the Atwood on our '81 is leaking. I have contemplated installing a new one myself, but I am stopped dead in my tracks when I see the grey and black flex tubing that is connected with clamps.
Would really appreciate some input as to how you reconnect the lines once the new unit is installed.
Also....do all Atwood units have the input/output connections in the same location, or do you have to do a lot of fabricating?
Thanks for looking...
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 02-24-2014, 10:46 PM   #13
groovzilla's Avatar
i haven't hooked up my electric/propane atwood h20 heater yet so this info will come in handy
good luck on your install and hopefully someone knowledgable chimes in
Old 02-24-2014, 11:09 PM   #14
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Just ordered the Atwood GC6AA-10E and should get it next week.
When we get return home on Saturday, will pull the old one out.
...still waiting to hear what is the best way to sever the old lines without making the job harder than necessary.
31' 1981 Excella II
or
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Water heater battery drain Bohemian Batteries, Univolts, Converters & Inverters 5 10-27-2011 12:22 PM
Water Heater Seal Ditter Water Heaters, Filters & Pumps 6 10-24-2011 03:13 PM
Suburban Hot Water Heater Smell/Gas Valve SafariSS Water Heaters, Filters & Pumps 2 10-23-2011 06:48 PM
Another @!#*& water heater pilot that goes out! Aage Water Heaters, Filters & Pumps 36 08-11-2011 10:51 PM
